Re: Hayward Ecostar pump.
That is very unfortunate.
Is the pump on a surge/lighting protection circuit? That seems to be the most common cause of failure. The electronics seem to be very sensitive to line spikes.
The Intelliflo is no different.
There is no surge protection on the pump circuit...where we are we have never had a problem with any of our electronics in the past that might indicate a voltage control problem. The sister pump that runs along side the failed one still works fine. If the Ecostar is susceptible to voltage spikes, then Hayward may need to consider building in surge protection in future units.
Have you searched Amazon and Ebay for the board to see if it's less expensive ?? Can you share the pumps numbers and or the control boards part number ??
