Re: Chlorine wont stabilize
We'll need more information to be able to help. Please put your pool's info into our pool chart. Also, tell us exactly what all you have added to the pool, meaning ingredients and not product names like "shock."
Pool Chart Entry Form
Welcome to the Pool Forum!
tlindsey18
I have tested everything but the CYA levels
And there you have it!
You need to KNOW the CYA level to know how high you need to keep the chlorine and how high you need to shock if there is a problem,
Also, do you have any combined chlorine (or are you only testing for total chlorine with an OTO test kit?)
My suspension is that you do have CYA. However, there is no way of knowing if it is too little, too much, or just right and there is another problem going on.
tlindsey18
my chlorine drops to zero reading with 36 hours
Depending on the initial free chlorine level, the type of chlorine being used (stabilized vs. unstabilized0 and the amount of use and sunlight the pool gets this could just be normal chlorine loss or might indicate a problem.
As Watermom said, we need more info about your pool, your testing method, and the poducts you are using.
ok..
i did the pool chart before, not sure what happened to it....anyway I completed it again. I am using liquid bleach (6%), muratic acid, when needed, and Borax. I have added 4 lbs of stabilizer from Home Depot (straight sanitizer) and then the liquid bleach every other day. Other than that nothing has been added, no triclor tablets or anything...
