Hayward SP 540 pool light
Hello- need to replace the old (1979-1981?) light fixture (no continuity on the feed-black wire-from the end of the cord to fixture). My question- would a SP0583L be a direct replacement? And what LED lamp would work also in this fixture?
Thank you,
Wes
Re: Hayward SP 540 pool light
Not something I can help with.
Your best bet may be to remove the lamp, carefully measure the niche depth and diameter, and take the ring + measurements to the oldest and ratty-est pool store around, and look for a pool service guy older than Moses. Somebody like that can possibly help.
I'll ask Waste and Waterbear, to take a look and post if they know anything, but generally finding parts to swap out for antique parts is an adventure expedition, with an uncertain outcome.
By the way, before you get too involved, you'll want to check and see if you can actually move the cable for the lap. If you can't pool the old lamp cord out, you won't be able to pull a new cord in. And builders OFTEN crimp the conduit to the light niche when they do installation, making the lamp un-replaceable.
I changed out the liner, so yes, the cord is freed up. I thought it was just the lamp that had expired. The fixture is potted, so no going in.
Lol, I like your thinking of a shop that's been around. But this being a copper fixture, you know they all went to the scrap yard for $$. Lol.
If you just need to replace the BULB, that's another deal - much easier . . . IF you can get a replacement gasket.
