Vogue Zenith HTH 6 way test results.
Ok im not sure if my pool is considered an intex type pool. I am about to start doing the BBB method as soon as my initial startup chemicals are used up. I have all the BBB and the kem tek 22.5 dichlor is on order (2), the k2006c test kit on order as well.
After adding conditioner this morning about 1lb i finally brought up my cya. let me know if these results are good or if i need to adjust anything.
PH-7.2
CL-5
ALK-60
CYA-35
HARDNESS-140
Re: Vogue Zenith HTH 6 way test results.
