Using the new Taylor test kit?
So I received the new test kit (pool still sitting in boxes in the soaking wet yard) and was curious if the 10 ml sample could be used for all the test or does that only work on some and you have to use the 25 ml sample for all the others? The directions are not real clear so figured I would ask the experts!
Re: Using the new Taylor test kit?
Use the 10mL sample for the chlorine tests. The other tests, just run as the instructions indicate. Check out this thread for some testing demos.
http://www.poolforum.com/pf2/showthr...eos-on-YouTube
Thanks watermom that's kinda what I figured but wasn't sure. Hopefully the weather will hold up and they will be starting next Monday and finish on Tuesday. I am afraid at this rate I won't be enjoying it this swiming season.
Nah ---- you've got lots of time left. Especially in Texas. (I used to live in TX myself --- Texas City.)
