Baquacil to Chlorine help
I've been using Baq since I purchased our pool several years ago and am tired of fighting it. CLOUDY, SNOTTY, ALGAE AND COST. Can someone explain the transition to chlorine. Neighbor has and inground pool and uses simple clorox and its beautiful and without problems. By the way ours is an above ground 18X34.
Re: Baquacil to Chlorine help
From the forum's homepage, go to the section called PHMB:Baquacil, Softswim, Clear Comfort, Etc. The top thread in it is a FAQ that explains the process. Until your registration is completed, you will have to log out first to be able to see the other sections of the forum.
Welcome to the Pool Forum!
membership upgraded. -ben
here's the Baquacil info: http://www.poolforum.com/pf2/showthread.php?179
