1 Attachment(s)
SWG Cell install opinions/suggestions requested.
All;
I am currently planning out my Aqualogic chlorinator install and am looking for opinions/suggestions.
I have 2 options for placement of the cell and flow switch as I have 2 pumps and filters on my pool. One pump works the deep end and the other one works the shallow end. Which would be the most beneficial location? The shallow end has 2 skimmers and 2 return lines, the deep end has 1 skimmer and the main drain with 3 returns (see the attached drawing).
I'm thinking of putting the cell and flow switch in the return line of the deep end filter and then pointing return jet #4 (see the attached drawing) into the shallow end.
Can anyone suggest a better configuration? Thanks.
NOTE: MS Paint (haha) "drawing" NOT to scale but is as close as I can get it
Regards,
Mark
Re: SWG Cell install opinions/suggestions requested.
Wow, 80+ views and no opinions? I guess what they say about opinions isn't true.;)
Someone must have a suggestion, even if you agree with what I had planned?
Regards,
Mark
Mark,
I will give this shot, but it would help if you could repost the drawing to include the horizontal dimensions to get a better feel of the size, or include a picture.
If there is a way to include all the returns, it would be most helpful, but putting the cell on the deep end returns would probably be the best bet at this stage without seeing what you have. As they say, a picture is woth a thousand words.
Pat
My Aqua-rite is plumbed just prior to the return. I think you want any bits filtered out so they don't clog up the electrolytic cells. I would put it in the deep end.... but I am not sure it would matter much if the pool is turned over at a regular rate. I am new to pools so I wouldn't base any decision on my advice.;)
Jake
1 Attachment(s)
Thanks for your opinions, I appreciate it. I will see what I can do about getting some measurements for you Pat. Anyone else?
Regards,
Mark
EDIT: Here's an updated picture. Thanks again. I hope it isn't too congested now.
Man, that's a giant pool!! If I were you, I'd just put two cells on it . . . one on each filter. Less use of one cell and that way you know you'll get the chlorine production you need and won't have to worry about cell life as much, and also, you won't have to run one filter longer than the other. I just think, with that size pool, two would be the way to go. AquaLogic? I think they'd advise 2 as well . . . What is your gallonage?
SJ
I wasn't aware I could run 2 cells off of one aqualogic. I'll have to go back and read the manual more thoroughly.
By my calculations I am just shy of 38,000 gallons. The pool store who worked with the previous owner of the pool said 40K.
Interesting option if I can run 2, thanks!
Regards,
Mark
Here it is from Goldline's website . . . FAQ section for Aqua Logic.
Q. Can I chlorinate a pool larger than 40,000 gallons?
A. Yes, if your pool is larger than the rated 40,000 gallon capacity, additional Aqua Rite Electronic Chlorine Generators can be wired to the filter pump relay. Each Aqua Rite chlorinator will sanitize an additional 40,000 gallons.
-Not sure how you would adjust or monitor each cell independently, but that's a question for them, I'd give them a call if I were you, I hear their customer support is excellent. Again, I think overkill is the way to go with Salt Chlorinators, that way you can run two at 40% output, or whatever it ends up being, instead of 80% on one cell. I researched the AquaRite thoroughly before installing it myself, and I seem to remember them recommending 2 cells for anything 40k and above in all their literature.
Good Luck! Let us know what you end up with and how it works. The AquaLogic is great, I love it!
SJ
