I have low filter suction. My pressure gauge is reading 15 - i believe I have suctioned up some leaves and they are caught in the pipes. Can I use a shop vac to remove leaves? If so, what steps are needed to continue with this process?
Please fill in your pool's information in our pool chart. It makes it easier for us to be able to help you.Pool Chart Entry FormThen, somebody here can better advise you.
Pool Chart Results
Welcome to the Pool Forum!
If you did suck up some leaves then maybe a shop-vac will work to suck them back out. However, the suction side of a pool pump produces way more suction than a shop-vac and they may be really jammed in the pipe. Worth a try though. You can also stick a garden hose in the inlet to the pump basket and pack some rags or something to give a tight fit and see if water pressure can blow the stuff out the skimmer. One reason to always use the skimmer basket.
Filters don't have suction; pumps may though. I assume you mean that there is little suction at the skimmer?
+ Is your flow out of the returns reduced?
+ What is your NORMAL pressure gauge reading?
It's not too likely that leaves are caught in your pipes. Sticks could be, but those won't be removed with a shop vac.
wow! Some great responses! I did fill out the PF form as requested and i am going to attempt some of the suggestions. You all are so helpful - thank you SOO much! I will let you know what happens - wish me success!
