my #s as of this morning is as follows
fc-6.0---on 25ml-5.4
cc-0.0
ph-7.2
ta-130
cya-9temp 88
why are kids saying its bothering eyes? look to me like water is in great shape please reply and thanks ahead of reply
cc-0.0
ph-7.2
ta-130
cya-9temp 88
CYA is 9?
CYA = 9???
FC=6
pH=7.2
TA=130
Because yourTA is at the top end of the "recommended" range...
I'd try raising pH by aeration to 7.6-7.8. That should help. You COULD use Borax to raise pH but the TA will increase with it. May not be a problem, but may be.
You can also try adding salt to the water, not enough to taste, but enough to make the water a little softer feeling. After all, tears are salty.
cya 90 sorry
Is it still irritating to the kids? Did you try areating?
Post a current set of water testing results. Your latest ones are from 6/23. Are the kids still complaining?
#s today at 8 am.
fc-5.0,4.4 on the 25ml
cc-0.0
ph-7.6
ta-130
cya-80
temp-90
yes some complaining? don't really see why? also what is the reagent (in the 2005 kit ) r-0002 used for i have been testing over 2 yrs don't see where that comes in what is it used for? and yes as far as aerating lots of splashing going on and the return is and always has pointed towards the surface for that reason and so i can see pump is running without going out to look
