Using my new Taylor test kit...HELP!
I got my new Taylor 2006 test kit and the first thing I tested for was chlorine. Can someone tell me if I am doing it right, because I am getting significantly different results than when I use my cheap Walmart OTO kit.
Here's how I tested:
I followed the instructions and put two dippers of R-0870 in 10 ml of water and I could not get the pink to change. So then I tried just one dipper of R0870 in 10 ml of water and then I used 16 drops of R-0871 to get it to change. Am I suppossed to multiply 16 drops times 5 ppm to get my chlorine reading? If that's the case that puts me at like 80 ppm!! When I test with my OTO kit, I get a reading of 3-4 ppm. Am I doing something wrong?
Re: Using my new Taylor test kit...HELP!
It's 16 drops x 0.5 ppm, or 8 ppm FC.
Unless you have a carefully calibrated OTO kit . . . that's within the expected error range. The FAS-DPD test is the more accurate result.
Oh, I see. I didn't read the instructions as closely as I should have. By the way, I am very impressed with the comprehensive Taylor 2006c Test Kit. I wish I would have bought one years ago. I would have saved a ton of money by not having to rely on the pool store people.
You also answered my next question which was do I rely on the new kit versus the old OTO kit, because the ph results are different, too, between the two kits?
sabres07
Yep! That's the way most people feel when they get that great kit!
