I have a Taylor 2006c test kit coming, but won't be here until the end of the week. In the meantime, I am using a drop test kit I fot from Walmart. It only tests to 5 ppm chlorine. I have used the dilute with distilled water to approximate my higher chlorine levels as I battle algae.
My question is this: how do I test for CC? On my kit you test for TC and then wait 2 minutes and look at the yellow range again. If it is vastly different, that means you need to super chlorinate, accodrding to the directions with this kit. There seems to be a lot of estimating when using this method. Is there a better way to measure CC?
