What do you use to seal the coupler to the vac hose? Just put a new one on and get air leaks at skimmer end.
TJG
TJG
What "vac hose" do you mean?
I use that term to refer to a vacuum hose, used with a pole and a vac head, to vacuum the pool. But I'm guessing you mean something different.
You are correct. I was having air leaks at both ends after installing new couplers. Problem was solved with the generous application of teflon plumber's tape.
TJG
Yeah, usually I use silicone or another sealant when replacing hose ends.
