New Pool Owner - Newbie at testing water - Need Some Guidance
I just had a new pool installed before the winter. Opened up the pool and was surprised on how clear the water was, aside from some fine dirt particles that came through a mesh winter/safety cover, which is used only during the winter due to the amount of snow we typically get in Ohio.
I purchased te recommended Taylor test kit K2006C and the Taylor K-1766 (salt test kit)
I am following the BBB methodology. I added 6 gals of bleach a week ago. Auto cover was on, pump circulating. When uncovered, water is slightly cloudy.
Initial test results:
FC = 2.0 PPM
CC = 0.5 PPM
PH = 7.0 - 7.2
Alk = 120 PPM
Calium Hard = 130 PPM
Cyanuric Acid = 0 PPM
Salt = 2,800 PPM
I know that my stabalizer is non existent. However, I am confused, as I thought I did not have to added any additional chemicals other than BBB. I know it should be in the range of 30-50 PPM. Is that my problem to cure the cloudy water? From reading other post, I know there is granular and liquid versions. Do I need to purchase this as well in addition to the BBB method? If so, what is the best way to apply it and how much.
Any help anyone can provide would be helpful.
Thanks.
Re: New Pool Owner - Newbie at testing water - Need Some Guidance
Bleach=chlorination
Borax= raise ph
Baking Soda=raise alkalinity
But yes you'll also need cyanuric acid (stablizes chlorine) and muriatic acid or dry acid (lowers ph).
More info: poolsolutions.com/gd/the-BBB-method-of-swimming-pool-care.html
Good luck! I'm sure someone will come along shortly to help you with your other questions
If your water is cloudy, odds are you just need to shock it to make sure you don't have a nascent algae bloom trying to happen. You will need to add CYA to the pool in order to keep the sun from consuming all of your chlorine, but the CYA in itself won't clear the water. Appropriate chlorine levels and filtering should clear the water. The liquid stuff is a good bit more expensive than the granular, but either one will work. If you're using strictly bleach for chlorination, then 30-50 ppm is a good range to shoot for. HOwever, if you have a SWCG system (I noticed you purchased a salt test kit?) then the CYA levels need to be higher in order to extend the cell life. That level varies by unit, but most of them want CYA in the 80-ish range.
You can either add it via old sock hung in front of a return, or add it through the skimmer and let it sit on the filter and dissolve. If you choose that route, don't backwash or clean your filter for at least 4-5 days, because it takes that long for it to dissolve. The label on the container should give you the appropriate dose for a 30 ppm level.
Thank you for your feedback. Should I be buying Cyanuric acid instead of "Stabilizer"? I know it must be the same thing, but I am referring to the chemical vs. a pool product that you get at the pool supply store?
Thanks so much. I will give it a try.
Stabilizer, Conditioner, and Balancer are all things that the companies use to label the bottle, but if you look at the ingredient list, cyanuric or isocyanuric acid is what you're looking for. If that's on the list, that's the right stuff. You can get it at WalMart, Home Depot, Lowe's, or just about anywhere else that sells pool supplies--you don't have to get it at the pool store.
