I am looking for suggestions in uprading my pump/filter. I have the original pump/filter that came with the pool. My pool info as well as pump/filter info should be in my signature.
Hi. Not sure what pump and filter you have by your signature. I think if you post what you actually have the folks here can help you better.
If you look around the site here, you will see the consensus is a large sand filter coupled with a two speed pump. Cleans well and saves electric.
Hope this helps.
Mike NJ
The pump/filter I have is the original that came with the pool. Intex krystal clear 635t 1500gph(which i assume stands for gallons per hour). I dont really know anything else about it. There was no horsepower ratings listed.
