need help reading cya results from K-2006 test kit
I think I may not be reading the cya results correctly. Instructions on K-2006 test kit say "Slowly transfer cloudy solution to small comparator tube until black dot on bottom just disappears when viewed from top." I thought that meant that I should not see the dot at all but my results are always 30. What am I looking for, when the black dot begins to turn gray? I'm using reagent way too fast this way...
Thanks!
Re: need help reading cya results from K-2006 test kit
Kateyru
Thanks!
The dot has to completely disappear. They don't give you very much CYA reagent, only enough for like 4 or so tests or something like that. You can order the CYA reagent in a large bottle and refill the small one for not TOO much money (around $15 with shipping).
Here's a link:
http://goo.gl/ntbFO
Taylor R-0013-E
Thanks for the response and the link!
