Re: Attempting a AGP install
I did it, about 10' but same deal. I have one skimmer and one return. I used flexible tubing to connect my buried pipe to the skimmer and return and to the pump and filter. I used unions between the hard piping and the flexible tubing to make assembly and winterizing eaisier. I purchased a mix of socket and npt unions from the same manufacturer so I could glue the socket end to the pipe and thread a tubing barb into the other side of the socket. You may also want to consider valves to shut the water for maintenance activities on the pump and filter.
Good Luck
Ya thats what I was thinking. Using unions where the pipe comes out of the ground. And also using shut-offs before and after the pump and filter to isolate them. Thanks for the advice.
