Minimum depth for Wanda Whale/Diver Dave/AquaBug
I've recently looked into the Wanda Whale/Dave/Aquabug cleaner from Hayward and have heard good reviews as an AG pool cleaner, but I cannot find information relating to the minimum operating water depth. I have an above ground pool with steel framing. The water is only filled to a level of about 20" for my 3.5 year old. I would never leave him swimming alone though. Does anyone have an idea of the minimum depth, or even just the height of the product itself ? I'm also thinking that adding a 90 degree hose connector would aid the cleaner in lower water depths. Other cleaner recommendations are also welcome, but not robotic cleaners. I'm looking into a low cost (and low labour) solution.
Re: Minimum depth for Wanda Whale/Diver Dave/AquaBug
I have Wanda the Whale and am happy with it. The unit is probably about 8-9 inches tall? You would probably need the 90 degree connector or else the unit will probably just tip over. (It still may with the connector anyways but not sure.)
