How Much Bleach
My current levels are;
FC 2.5
CC 0.5
TC 3.0
PH >7.0 (I just finished dropping my ALK and aeration is ongoing)
TA 90
CH 80
CYA 55
How much Walmart 6% do I need to add to get a 2.0ppm rise? Is there a standard calculator located on the forum?
My pool is a AG 17,500 gallon.
Re: How Much Bleach
Sorry, the Ph is less than 7.0, not greater than.
Re: How Much Bleach
In 17,500 gallons of water, each 2.5 quarts of 6% chlorine should give you just over a 2 ppm chlorine rise. There are a couple of pool calculators you can use--one is www.thepoolcalculator.com, and the other one is Bleachcalc. I prefer Bleachcalc for ease of use, but I have it set on my desktop so I'll have to look around the forum for the link to it. When I find it I'll try to come back and post it here.
Re: How Much Bleach
It is post #2 in the following thread.
http://www.poolforum.com/pf2/showthr...18-bleach-calc
Your most critical concern though, is that low pH! Get it above 7.0 ASAP before it damages your pool or equipment!
Re: How Much Bleach
Thanks Watermom, my Ph is now just over 7.0. I've had good luck with aeration.
