Re: Determining pool volume
		I can't help you with the volume but bleach calc has a settings tab that will let you enter your numbers as gallons or liters. It will also save the numbers for your pool so you won't have to enter them everytime you use the calc.
		The forumla for a rectangular pool is:
 length (in ft) x width (in ft) x average depth (in ft) x 7.48 (gallons per cubic foot) = volume in gallons.
Using BleachCalc and assuming an average depth of 5.75 feet, I get just under 28000 gallons.  The steps probably only add about 300-400 gallons.
You can change Michael's BleachCalc from the metric to the imperial system by selecting "settings" from the "more calcs" menu.
		If you want a real accurate number, you'll need to measure it:
measure the depth of water in a line down the center of the pool every 1 foot (ignoring the stairs for now) , you  should end up with  37 measurements (0 ft, 1ft, 2ft, .... 35ft, 36ft).
Calculate the "average" depth for each 1 foot long x 18 feet wide section by averaging  the depth reading at start and end of that 1 foot section but subtracting maybe 2 or 3  inches for rounding at the sides of the pool.  Then multiple this average depth for this section by 18' x 1' to get xxx cubic feet for this 1 ft long section
Do this for all 36 sections, add up all 36 values of cubic feet, multiply by  7.48 gallons/cu ft to get gallons.
You'll need to 'fudge it a bit for rounding in the deep end especially, and also the stairs, but this shoudl get you within 5% of real value
