Originally Posted by jnorris
...PB recommended that I shock once a week using the Cal Hypo. But I'm hearing all of you say that maybe I shouldn't have to shock once a week. Could it be that he is recommending shock once a week, to sort of "make up" for the fact that my FC is 2ppm? Or should I just shock when my test results warrant (like when CC is above .5)?
Yes, only when you need it (CC above 0.5 ppm). You'll start to develop a feel for when that's going to happen by testing regularly and paying attention to what's going on in your pool (a bunch of swimmers, lots of kids who leave little presents, lots of leaves and stuff, etc.) but there's not any good reason I know of to shock on a schedule.
Does it make a difference that I live in SC, and we have 90's and 100's in the summer, plus we have a heater?
For chlorine, not really. Your chlorine demands may be higher than for a pool in the great white north but procedurally, everything's the same.
On the heater, there are some who theorize that you need to keep more calcium in your water to protect your heater and you'll find some threads in the forum that speak directly to that issue (though I've seen nothing that was very definitive). I don't know enough about that for my opinion to be of any value.
Regarding TA, I guess with a PH of 7.6, I definitely don't want to raise that too much, so I guess the baking soda is the way to go to raise TA. He was getting his number of what my TA should be, based on what I was using to shock (cal hypo) and sanitize (chlorine sticks). He said it should probably be between 100 and 140. So he said to raise it to 120 we would add 16 lbs of baking soda. So I guess that will be OK to do?
Your TA is in the normal range now. It won't hurt anything to raise it but it probably won't help much of anything either. I'd suggest you leave the alkalinity alone and see what happens naturally. If you have trouble controlling your pH over the next few weeks, you can raise the alkalinity a bit then. If you do decide to do it, add half or even a quarter of what the PB recommends (or better yet, download mwsmith's BleachCalc and figure it out using that), wait a day, test, and repeat as needed until you get it to where you want it.
Regarding converting to bleach for weekly sanitation, how do I add it? I don't want to bleach out my beautiful new liner. PB told me that when I use the Cal Hypo to shock, I should add it very carefully and very slowly to the skimmer basket, so that it gets deposited in the filter and gets distributed that way. Can I (should I) pour bleach in the skimmer? What would be the typical amount I would add each week: are we talking maybe one or two jugs, or 10 jugs? Since I will be the one doing the work, I don't really want to be loading up my grocery cart with 10 jugs of bleach each week.
You can add bleach through the skimmer or just pour it in the pool in front of a return or walk around the pool adding small amounts as you go. None of those methods should have any appreciable affect on the liner.
The amount of bleach you'll use depends on too many variables to give you a firm answer. 10 gallons per week is not out of the realm of the possible but neither is 3 or 4 gallons per week (or eve less at some times of the year. You can also by liquid chlorine in higher concentrations (10% and 12.5% typically) at pool stores; that would save you some lugging around. Be warned, however, that the higher concentration bleach tends to degrade faster and that it will eat holes in clothes and other things more readily than the household stuff.
One more: PB said in this area, most pools end up with mustard algae at some point in the summer. He recommended that I call him when this happens, and he will come out and put in a copper algaecide that is made a special way so that the copper won't come out of the suspension and damage the liner. Does this make sense? I asked him about using polyquat, but he said the copper stuff works better.
It's very unlikely that you'll have to deal with any algae if you're diligent about maintaining your water chemistry; especially the chlorine level. Remember that your PB has been teaching people to run fairly high CYA levels which supresses chlorine's sanitizing and oxidizing action and that could well be why they're seeing annual algae blooms. In the (hopefully unlikely) event you do have a bloom, most people here will tell you to deal with it using chlorine first, 60% polyquat second (though others here will tell you that the poly is better as a preventative and not very good as a remedy), and copper based algaecides not at all. There are other opinions here, but I think that's a fair summary of the party line.
Once again, I thank all of you for the great education. You people are the best!
Judy
