Hayward H Series Wiring Issue?
Guys/Gals,
I'm new to this forum and I need some help. I currently have a Hayward H series (H350IDL2) heater on my in ground pool here in Houston. My dang dog chewed the wire leads off of the Temperature Limit Sensors on the water outlet side of the heater. For the life of me I can't figure out how this was wired as only one lead comes from the control board area of the unit. There is two sensors (stack on top/right next to each other) and there use to be a rubber boot covering the contact leads of the sensors. Does someone have a picture of an install or diagram of how this sensor is hooked up as I cannot figure it out and the manual from Hayward is useless. Do both sensors get hooked up in parallel or is only one used? Does one side of the sensor hook to the power and the other side ground? Also, can I buy a new electrical boot/cover to replace the one's destroyed as I can't find it anywhere on the web? Any help is appreciated.
Dave
PS
I'm really pissed at my dog right now - LOL!!!
Re: Hayward H Series Wiring Issue?
Got it solved and rewired - thanks.
Hi Dave and welcome to the Pool Forum. Glad you got the problem fixed. I totally understand dogs chewing everything in site. I have three golden retrievers -- one 7 year old and two 9 month old pups, all females. Those pups chew anything that doesn't chew them up first. But, they are adorable and so much fun.
Hope you enjoy being a part of our forum!
