I have a 12v light run off a GFI protected transformer, the light is mounted in the wall about a foot below the water line. The other day while cleaning pool I swear I noticed water behind the lens. :eek:
This can't be normal can it? :confused:
No, there should NEVER be water behind the lense.
You probably either have a bad gasket (most likely) or a cracked glass. Of course the light fixture body itself could also have a hole, but that is not as likely.
You will want to have this problem fixed ASAP.
Josh
