chemistry for filling pool for the first time
Hi,
we did some renovation this year on the pool including fresh paint. I've maintained pool chemistry (using ben's kit) but have never started with an empty pool. On friday we're going to start filling the pool and I'm wondering what approach I should take. Are there any chemicals I should be adding that I don't normally add?
the pool itself is 36K gallon gunite.
tia,
jd
Re: chemistry for filling pool for the first time
Nothing other than the regular stuff. As the pool is filling, drizzle in some bleach after each foot or two of water is added. It doesn't take long for a freshly filled unchlorinated pool to turn green! Of course, you'll also need to add stabilizer once it is filled since there won't be any in there.
Please tell us that you are not filling from a well! We have had so many pools here on the forum this year filled from wells that are dealing with metals issues. I don't want you to be one of them!
Keep us posted how it is going and also let us know if you have questions along the way. We'll be right here!
thanks, no, we don't have a well. So I'll need to add cya, something I've not had to do before. what would be a good target for cya level? Maybe I should use chlorine tabs for the first couple of weeks as I recall they contain cya?
A good beginning target is 35-40. You can always add more if you find that you need it, but you can't get rid of it if you go too high except by draining. You can use trichlor because they do contain CYA but it will take some time before it builds up enough to help you. If it were my pool, I'd do one of 3 things.
1. Just buy some CYA and add some separately to get to around 40. (Probably about 11lbs.) You can add it slowly to the skimmer while the pump is running and then keep the pump running 24/7 and don't backwash for at least 4 or 5 days to give it time to dissolve. Also, don't test for CYA for at least a week or else you'll just be wasting your reagent as it can take that long to dissolve.
2. Add enough CYA separately to get to about 20 and then use trichlor pucks for awhile and monitor CYA. When you get to 50, stop using the pucks.
3. Use dichlor powder for awhile and monitor the CYA and stop when you get near 40. (Dichlor will put the CYA in faster than Trichlor. For every 10ppm of cl that it adds, it will also add 9ppm of CYA. With trichlor, it adds 6ppm of CYA per 10ppm of cl added. But, dichlor dissolves much faster than trichlor does so it wouldn't take as long for you to get a CYA reading than if you just use pucks.)
Any of the 3 ways will work but with any of the methods you choose to do, you'll have to add chlorine frequently in the first week or so. Until you get enough CYA dissolved and into the pool and can register a reading, you'll lose chlorine quickly to the sun.
I will caution you that dichlor and trichlor are both very acidic so if you use either of these products, monitor your pH.
