My numbers are: th-250, tc-3, fc-3, ph-7.6, ta-120, stabilizer-100
I have turned my chlorine feeder down to lowest setting. and I want to use up the calcium hypochlorite 65% chlorine granules before and if I switch to bleach. I know the chlorine feeder with pucks has driven my cya up way high so I turned it down to lowest setting, I guess I will turn it all the way off but unsure about that. how much cal. hypochlorite should I use get my water clear again?
