Anyone use this chemical before? Supposed to act like a solar blanket and reduce heat dissipation? I am skeptical and looking for anyone that has used this product.
same stuff that is in the solar fish. Check out the thread on solar fish for an in depth discussion. http://www.poolforum.com/pf2/showthr...ght=solar+fish
Hope this helps.
20-30% savings in heat loss MAX - and that's only if you turn your pump off overnight to let the water sit very still (allowing the chemical to create a nice even barrier on top of the water).
I've tried the fish after a solar cover started to delaminate - not impressed - using a standard solar cover again.
