How do I know when it's time to replace my salt cell
That I can't help you with, but there are many SWCG people on the forum who will be able to. I just wanted to say hi and welcome to the Pool Forum!
Hi Jim;
Two questions:
#1 - What is the model / make of your SWCG?
#2 - Did you have a registration here before, with a similar user ID, and if so, what was your email provider then?
( I don't need your old email address, just the provider name. The right answer will get you a much less restricted user account.)
I think the old provider was Juno.com. I have an Aqua Rite.
Jim
Hi Jim.
Can you tell us what the diagnostic displays are? (when you press the black button next to the display LED, can you tell us what it shows for each push - IIRC there are 7 different #s that will be shown, so 7 pushes of the button)
Jim, i was at one of my local pool stores buying a cover and noticed they had a aqua rite cell tester so i went home and unhooked my cell and took it in for a test and it passed the test. so check your local pool stores.
They have one at my pool store as well. From what I could tell they basically have a control panel device that does the same checks your control panel already does, plus they stick the cell in a bucket of water to see if it's creating bubbles and therefore "working". This is probably the more important part of the service they provide since folks like me can't run the pump without the cell as the water would spill everywhere...
If it were me, I'd do this:
1. Look for errors on the control panel.
2. Make sure your CYA and salt levels are within your manufacturers recommended range.
3. Follow the cell manufacturer's cleaning instructions; probably do an acid wash.
4. Test your chlorine level early in the evening (after sundown, though).
5. Run your system with the cell at 100% setting; test chlorine level after a few hours (or in the morning).
6. Is your chlorine level higher than it was during the first test? If so, cell is working. (don't forget to adjust your cell output back down).
You should also see little bubbles coming out of the returns while the pump/cell are on and the cell is at 100%
Here's the Hayward/Aquarite cleaning instructions: http://www.poolforum.com/pf2/showthr...2392#post72392
