Pool still not clear! (Have numbers attached)
We've been running our pump non stop for the past week. Shocked it twice with bleach.
Today's numbers are :
Total Chlorine = 10
Free Chlorine = 10
pH= 6.8
Total Alkalinity= 80
Cyanuric Acid = 20
Water is definitely cleaner, but still green. Can see the steps in the shallow end.
Any ideas? Are we on the right track or should we add something else?
BTW - we are trying to go the BBB route. Have a salt water generator. Not sure how many gallons exactly. It's a fiberglass pool 18'x44'.
Any help would be MUCH appreciated!!
Re: Pool still not clear! (Have numbers attached)
Doesn't really sound like you need much help, other than some encouragement to "stay the course". But . . .
+ Keep your chlorine high by adding bleach in the evening.
+ Add borax, a box at a time, 1 box per 10,000 gallons, till your pH is above 7.0. You can add 2x per day, but add through the skimmer with your pump running.
+ Add some more stabilizer AFTER you get the pool cleaned up.
Ben
If your CYA is 20, then you need to keep your FC at 12ppm. With a vinyl liner, you are safe to go up to, but not beyond 15ppm, which will speed up the algae killing.
Sounds great! Thanks for the quick reply!!
CarlD
We don't have a liner. Fiberglass pool here. - thanks for your response!!
PoolDoc
Ben
How much bleach do you think we should add tonight?
We would need to know the volume to suggest how much bleach to add.
