I am going to have a 12x2x2 waterfall which will run off of its own pump and plumbing including a bleed line to control the flow.
However I have decided to add two water features to my pool, a beach entry foam jet and two deck jets/aerators. These I am going to run off of the main return pump and off of the main returns. I have come up with a plumbing diagram for these, I would like to run it by you people to see if it makes sense.
I am going to turn on and off the water fatures with a Jandy Valve Actuator and I will manually tune the individual features' flow with two 3-way jandy valves. I figure once I set it it'll be set for a while and I can just turn them on and off remotely.
Here is a link to my diagram:
http://www.gregtakacs.com/dpr/pool_valves.jpg
let me know if there is a better way to do it.
