Re: Please help, green pool
What kind of shock are you using -- meaning ingredients? How often are you adding it and how low is the chlorine dropping before each dose? What type and size pump do you have? What kind of test kit are you using?
Don't use any more triclor tabs or dichlor shock if that is the type of shock you used because they will cause the cya level to increase and it is high enough.
Thanks for your reply,
Sorry, i left out some info. Realized it after posted, but was moderated still so couldn't edit.
OK was using dichlor shock. NOT USING ANY MORE. Stopped about 3 weeks ago. and went to plain %6 bleach. Still have some trichlor tabs in floater. Been testing 3 times a day and adjusting to keep levels around 15-20.
Using stay rite cartridge 100sq ft. Do i need to be more specific, if so i will go look and get more info.
You're doing the right things except, take the floater out of the pool. No more trichlor; your CYA is high enough. Are there any other products you have added? There has been no change in the color since you began? Still green? Do the walls feel slimy? Do you fill from a well?
I would also bump the chlorine up to 20 ppm, since the CYA has gotten so high Keeping it at 15 is walking a fine line between enough and not enough (see the Best Guess chart in Watermom's and my sigs)
Watermom
OK 10-4 on the floater.
The only other thing i have put in was some muratic acid because the PH was high.
aylad
OK will do.
Do you think that is all that i need to do for now?
Thanks you guys for the help!
-Micah
that should work for now- get the FC a little higher, and it should start clearing away...
