Re: Still can not stop stairs from staining.
Metal remover doesn't actually remove the metals--the only way to remove them is to make them drop out of suspension (which is what's happening to your steps) and filter them out. The other option is a metal sequestrant, which keeps the metals in suspension so that they're still technically there, but not visible. Pooldoc or Mbar are the ones to advise you better on this, but just know that once you have metals in the water, they're going to be there, unless you filter them out. MIght want to take a look through the "metals" forum, there are lots of threads from others that have metals and outline what they've done to deal with them.
