Hi, We just bought a house with an in-ground pool. It is about 22,000 gallons. We ran some test at the local pool store and the level of copper in this water shows 5ppm, which I was told is very high. Is there a way to remove copper from the water or should we drain the pool? If we drain the pool, how do we clean the pool (fiberglass) so that the copper is actually removed? We will replace the copper pipe in the ground as well.
Thank you.
