blessedbeingmom
			We received our Taylor K-2006 test kit today.
Congratulations! You'll never have a pool store test for you again!
As a reminder, our pool is an Intex above-ground, metal-framed pool, that holds around 4,600 gallons (closer to 5000 when fuller after it rains).  We've had it for a bit over 2 weeks now, and are in the process of switching to BBB method.  Lately, we've only added bleach (6%).
If you want to raise your FC by 6ppm you'll use 2 quarts of bleach (6%).  5,000 gallons is a great number because calculating bleach addition is really, really simple.  The Rule of Thumb is:
One Gallon of Bleach adds to 10,000 gallons the same # of PPM as its percentage.  6% adds 6ppm, 12.5% adds 12.5ppm.  Just half the amount of bleach and you get the same result!
Meanwhile, Intex filters are a little weaker than others, but if you stay on top of your water with daily maintenance according to the B-B-B method it will do just fine--I had an early Intex for 3 years that I last used in 2002.  With B-B-B, I never had a problem.
These are the numbers we got.
FC 2.0 ppm
CC 0.5-1.0 (was hard to tell, appeared clear after 1 drop, but then became slightly pink after sitting for a minute, so we added another drop)
If it goes clear after one drop you have, AT MOST, 0.5 CC. If you want to be really particular about it, re-run the FAS-DPD test using 25ml rather than 10ml and each drop is only 0.2ppm, rather than 0.5ppm.  You may find your CC disappears after one drop again--in which case it's actually at or below 0.2ppm--not much of a problem.  If you let it sit, it will become pink again--so don't do that because it's a false reading.
pH 7.8
TA 110 ppm
Here Waterbear and I disagree slightly. YMMV ("your mileage may vary" :rolleyes: ).  But he would agree on this: If you find you have NO problems with constantly rising, falling, or just changing pH, TA's not a problem. I've NEVER had unstable pH whether my TA was 140, 120, or 80.  Whenever I've had a pH problem it was due to a clear, reversible condition.  IF you CH (below) gets very high AND your TA gets around 200, you MAY get milky water and scaling...so, unless your pH isn't stable, don't worry and don't "fix" what isn't broken.
CH 140 ppm (vinyl pool, don't think this matters much)
Right.  Again, when it gets to 400 or 500 AND T/A is high, such as 200, you may get milky cloudy water from the calcium.  The cure is lowering T/A.  But, since you are testing, you won't have that problem.  Since I have a vinyl pool and I don't use Cal-Hypo for chlorine, I tend to check CH no more than twice a summer, but I check T/A weekly.
CYA - We guess maybe a bit less than (but near) 30 ppm... We could still faintly see the dot at the 30 ppm mark.  We actually went to the top and the dot was still extremely faintly visible.
The rules on CYA reading are a bit ambiguous, but it's best to hold it at your waist, on a sunny day, with your back to the sun.  If you can see the dot when the cell is full, you have less than 20ppm of CYA and need to add it.  Remember: unless you use the new, pricey liquid CYA, it takes time to dissolve, up to a week before it shows up, so don't even bother testing for a week after you add CYA and save your reagent (consider ordering a 16oz refill bottle).
Now, I need to find out what to do with these numbers.  Do we need to add more stabilizer?  We leave in a bit over a week to go out of town for a week, so I want to get things in order before we go, so we don't come home to a pool full of algae like we did the last time we went out of town (and it was only 4 days then, but we hadn't put any chlorine in yet, because we were stuck on "balancing").
How do we know what is a good chlorine level to aim for?  I've got the pool calculator handy, so I can figure out how much to add.  Do we need to worry about this CC level?  Is this pH level okay?
Thanks for any advice!
