Forum: Pool Water: Treatment, Testing & Problems (P)
Water treatment sections are HERE!
Sub-Forums Last Post
  1. Swimming pool chemistry and water care for Intex pools, and other small above ground pools WITH a pump and filter, between 1,000 and 12,000 gallons
    Forum Actions:
    Forum Statistics:
    • Threads: 375
    Last Post:
  2. Which kit? Why? How? What does it all mean?
    Forum Actions:
    Forum Statistics:
    • Threads: 1,994
  3. Bleach, cal-hypo, trichlor, dichlor, shock and STABILIZER: when, where & how.
    Forum Actions:
    Forum Statistics:
    • Threads: 1,456
  4. Trichlor feeders, salt-based generators and systems, feed pumps, and more.
    Forum Actions:
    Forum Statistics:
    • Threads: 1,057
  5. Issues w/ stains, from iron, copper, & other metals & with copper-based products: Nature2, Vision, Frog, Ionizers, skimmer pills, Pristine Blue, Chlor-Free & . . . ?
    Forum Actions:
    Forum Statistics:
    • Threads: 500
    Last Post:
  6. High alkalinity and calcium levels are much trickier to resolve than the pool books indicate
    Forum Actions:
    Forum Statistics:
    • Threads: 334
  7. Green & slimey, mustard lined, pink in the pipes, black algae mats; Green Treat, Yellow OUT, Yellow Treat, copper algaecides, & more.
    Forum Actions:
    Forum Statistics:
    • Threads: 940
  8. Chemical or water problems that don't fit elsewhere?
    Forum Actions:
    Forum Statistics:
    • Threads: 976
    Last Post:
  9. Using a Taylor DPD-FAS based testkit? Questions & answers here.
    Forum Actions:
    Forum Statistics:
    • Threads: 313
  10. Alternatives to chlorine. How to use PHMB (Baquacil). How to recover from using it
    Forum Actions:
    Forum Statistics:
    • Threads: 161
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 15 replies or 150 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
