Page 1 of 85 1 2 3 11 51 ... LastLast
Threads 1 to 30 of 2523
Forum: --cleanup--
  1. Question Closeing Pool
    What do you recommend to winterize a pool that uses the BBB method in Northeast Ohio?
    Started by JOHNL‎, 09-16-2017 08:51 AM
    09-16-2017 08:51 AM Go to last post
  2. Quote for variable speed pump
    Putting in new pool. Standard pump included in base price is Jandy single-speed 3/4HP Stealth. For $1,100 can upgrade to a Jandy FloPro variable...
    Started by teberlein‎, 09-08-2017 02:37 AM
    09-08-2017 02:37 AM Go to last post
  3. Fiberglass steps and pool liner need replaced-options
    Fiberglass steps has a crack and leaks, also the pool liner has a leak and a tear at the bottom of the pool. I have an inground pool and we live on 2...
    Started by kstephenson11‎, 09-07-2017 01:04 PM
    09-07-2017 01:04 PM Go to last post
  4. New member, New In Ground Pool Owner
    Bought a home with a 20x40 concrete in ground pool with liner. 3.5ft shallow end, 12ft deep end. This is a LOT more pool than our previous two above...
    Started by KennyKaraoke‎, 08-29-2017 02:52 PM
    08-29-2017 02:52 PM Go to last post
  5. New Here!
    Hi All, Thanks for the add! I currently have a 1700 gallon 12' x 30" Intex frame pool. Like everyone here, I'm looking for help with water...
    Started by blueangelmilw‎, 08-27-2017 06:41 PM
    08-27-2017 06:41 PM Go to last post
  6. New pool owner
    Hello, We recently had a cement, inground pool installed in our yard. We live in Marathon in the Florida Keys and everything is very expensive...
    Started by bh0526‎, 08-26-2017 08:46 AM
    08-26-2017 08:46 AM Go to last post
  7. Cloudy and green
    I've been using the BBB method all summer and it was working perfectly until about a week ago. Within the space of four hours the pool went from...
    Started by Eva T‎, 08-25-2017 12:58 PM
    08-25-2017 12:58 PM Go to last post
  8. H150FD Pool Heater blowing fuse
    Heater shows error code bd. Hayward says check the FC4 fuse on the fuseboard and sure enough it was blown. Replacement fuses keep blowing after...
    Started by devastavit3‎, 08-19-2017 02:25 PM
    08-19-2017 02:25 PM Go to last post
  9. new user
    Just trying to get set up and this will not let me search yet. Hoping it will soon. :-)
    Started by mann4christ‎, 07-01-2017 12:05 PM
    07-01-2017 12:05 PM Go to last post
  10. Registering
    Hi I would like to post in the forums. What do I do? Thanks
    Started by SEN69‎, 06-30-2017 09:09 PM
    06-30-2017 09:09 PM Go to last post
  11. BBB Method for non salt pools?
    I have a 16,000 gallon in ground pool. It is not a salt pool. By using Borax to raise the PH in it, am I doing something wrong? The PH and...
    Started by niceguy808‎, 06-30-2017 05:54 PM
    06-30-2017 05:54 PM Go to last post
  12. Plaster Color
    Looking for pictures of PlasterScapes Blue Harbor pools, specifically when only half the recommended dye is used to achieve a lighter shade of this...
    Started by Nemesis58‎, 06-29-2017 10:33 AM
    06-29-2017 10:33 AM Go to last post
  13. New User
    Hello everyone new user with 20x40 vinyl unground currently have a leak so looking forward to some advice
    Started by Challenger13‎, 06-29-2017 10:09 AM
    06-29-2017 10:09 AM Go to last post
  14. Thumbs up New user Nathan b
    I'm excited to find ur site I just build a in ground pool with spa It's my first pool I have been getting water tested a pool store My builder...
    Started by Nathan b‎, 06-28-2017 07:42 AM
    06-28-2017 07:42 AM Go to last post
  15. hello friends, im in need of help with my pool.
    hello everybody im new to the forum, im very glad that i found this page b/c im in need of help with my pool. I have these two inlets on my pool wall...
    Started by MacMarv‎, 06-27-2017 04:50 PM
    06-27-2017 04:50 PM Go to last post
  16. Where are todays threads
    Where are todays threads not last years todays.june 26,2017
    Started by 1charlely‎, 06-26-2017 11:27 PM
    06-26-2017 11:27 PM Go to last post
  17. pump filter glass had alot of air bubbles
    pump filter glass had alot of air bubbles when i used my pool cleaner,I had the arrow between skimmer and main drain,but when i took out the pool...
    Started by 1charlely‎, 06-26-2017 10:47 AM
    06-26-2017 10:47 AM Go to last post
  18. Smile Intoduction - What sort of Pool is better to be considered for a long run.
    Hi, I'm Kristin. I with my husband Matthews moved in to town few months back. We presently own a 0.193 acre plot which holds 4 Bedroom house. We...
    Started by Kristinah18‎, 06-26-2017 02:36 AM
    06-26-2017 02:36 AM Go to last post
  19. Unhappy New Pool Problems
    Does anyone use or reply to these forums anymore? I have been trying to clear my green 25,000 gallon non-salt water pool for 7 days (sand...
    Started by Beginnerswimmer‎, 06-25-2017 05:31 PM
    06-25-2017 05:31 PM Go to last post
  20. Brand New Pool - bleached by pool start up
    We have a brand new pool that was put in last summer with a dark liner. We had the pool company open the pool. The liner is bleached and looking...
    Started by SEN69‎, 06-25-2017 04:50 PM
    06-25-2017 04:50 PM Go to last post
  21. AG pool chemical setup
    Hello! I have a 12x18ft oval above ground 52in wall; Waterway Carefree sand filter/pump combo 1.5 horsepower; Swimline pool liner 20 mil. First...
    Started by molk12‎, 06-25-2017 03:32 AM
    06-25-2017 03:32 AM Go to last post
  22. Little Bit Confusing
    Wow... this is little confusing.. I can't tell if I am at poolforum.com or at troublefreepool.com They seem to be different sites, but I got here...
    Started by LordNorth‎, 06-24-2017 08:53 PM
    06-24-2017 08:53 PM Go to last post
  23. Advice for durable solar cover
    Looking for suggestions. 16 X 32 inground
    Started by Gdurham‎, 06-24-2017 10:45 AM
    06-24-2017 10:45 AM Go to last post
  24. Swamp monster help please!
    Hello and thanks for taking the time to read. We have a 20 x 40 foot 36,000 gallon concrete w/ plaster in-ground pool with a Pentair Triton II...
    Started by aghaferi‎, 06-24-2017 08:56 AM
    06-24-2017 08:56 AM Go to last post
  25. Skin sensitivity
    We have just ordered our first pool and should be arriving in a few days. My son has sensitive skin and I was wondering what is the best way to...
    Started by sticc‎, 06-23-2017 10:07 AM
    06-23-2017 10:07 AM Go to last post
  26. please re-score my registration
    i have completed the Pool Chart Entry Form, and done the below + 'like' the PoolForum on Facebook + 'follow' the PoolForum on Twitter + asking a...
    Started by cjusticesmith‎, 06-23-2017 09:57 AM
    06-23-2017 09:57 AM Go to last post
  27. best sand
    what is the best sand to but under my liner for an inground pool
    Started by cjusticesmith‎, 06-23-2017 09:49 AM
    06-23-2017 09:49 AM Go to last post
  28. Hello -- newbie here
    have utilized this forum before, but always as a lurker. have some questions on pool operation and I look forward to this.
    Started by tanqtonic‎, 06-23-2017 12:41 AM
    06-23-2017 12:41 AM Go to last post
  29. New, just posting to get better forum functionality, teeny tiny Intex pool, lol...
    Hi -- 1st time pool setter-upper, with a teensie-weensie 8 foot Intex pool for the grandkids, just learning about water maintenance and the...
    Started by Boston Bob‎, 06-22-2017 06:46 PM
    06-22-2017 06:46 PM Go to last post
  30. Hi. New pool owner signing in.
    Hi all, We are currently have an IG pool installed. Had a standard 24' round AG pool growing up and owned one at a previous home. This is our...
    Started by Dougget‎, 06-20-2017 09:10 AM
    06-20-2017 09:10 AM Go to last post
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 15 replies or 150 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
