+ Post New Thread
Threads 31 to 60 of 60
Forum: -- Subscriber Posts --
Initial forum for subscriber posts, so their questions get priority attention.
  1. Sticky Thread Sticky: New Directions for PoolForum in 2018 (in revision)
    __________________________________ What’s been the problem? There are several, including personal ones I am not going to explain, but a major...
    Started by PoolDoc‎, 04-09-2018 03:52 PM
    09-30-2018 07:41 AM Go to last post
  1. Separating marketing from fact - pebbletec vs fiberglass
    Weighing fiberglass vs gunite and running across marketing like this:...
    Started by jwramr‎, 07-14-2014 09:07 PM
    07-14-2014 11:29 PM Go to last post
  2. How do I deal with nasty surprise behind pool light?
    I noticed sometimes I will get a little algae in the crevices around the pool light (poor circulation there?). Today I decided to pull the light out...
    Started by JimK‎, 07-09-2014 02:40 PM
    07-09-2014 04:20 PM Go to last post
  3. filter cleaning
    Odd question. Due to my pump issue I feel a need to clean my filter often. Can you clean you filter too often ?
    Started by Wrisk‎, 07-06-2014 01:17 AM
    07-08-2014 08:35 PM Go to last post
  4. Question What type of chlorine to use? The cheapest?
    I saw some videos and read some things on the BBB Method that said that ordinary household bleach will work fine for pool use, but from what I've...
    Started by mitchryan912‎, 07-03-2014 05:32 PM
    12.5% sodium hypochlorite, chlorine bleach, clorox
    07-03-2014 06:03 PM Go to last post
  5. where to pay for yearly subscription
    went to pool forum to check yearly sub. I got an email but I cant find where to pay as email is gone I went to the forum itself. Thanks Dave
    Started by dansdad‎, 06-27-2014 04:54 PM
    06-27-2014 08:14 PM Go to last post
  6. Low pH, Hardness, Alk, where do I start?
    CYA 35 (finally dissolved all the stabilizer yesterday) Hardness 40 Alk 40 pH 6.8 or under (was around 7.0 yesterday) Chlorine: Been using bleach...
    Started by ChrissyInOregon‎, 06-10-2014 05:34 PM
    3 Pages
    1 2 3
    06-19-2014 08:34 AM Go to last post
  7. Troubleshooting an Aquabot cleaner
    New problem is I have a pool built in 1972 with diving board. Kids love it. I have an aquabot turbojet that has been a lifesaver to clean the...
    Started by gamtire1200‎, 06-14-2014 07:14 PM
    06-14-2014 09:42 PM Go to last post
  8. hello all. New user
    Just wanted to say Hi and thanks. Been on here reading for the past few days as I battle my pool problems. Still dealing with cloudy water but after...
    Started by TC213‎, 06-10-2014 07:24 PM
    06-11-2014 09:45 PM Go to last post
  9. Question Pool on a timer
    First post to the forums, and not the last post. I put a digital timer and contactor on my pool pump power feed last year. I don't have a two...
    Started by Progas‎, 06-10-2014 03:46 PM
    06-10-2014 04:56 PM Go to last post
  10. First K-2006 test
    Finally got the test kit last Thursday. I was indisposed until today. FC 7 CC <.5 pH 7.6 CYA (result verified by my "chemist") 40 Looks...
    Started by Pappy‎, 06-08-2014 04:03 PM
    06-10-2014 03:45 PM Go to last post
  11. CYA not measuring as expected
    New fill in my 40k pool this Spring. Started with dichlor for chlorine and to add stabilizer. Added ~10lbs. of dichlor to use up the bucket. Then...
    Started by Mm_putnam‎, 06-05-2014 09:25 AM
    06-06-2014 01:53 PM Go to last post
  12. Gunite pool with brown stains
    First off, I am not very pool savvy. My pool is 30 years old. Last summer just before I closed I had some patches re-plastered and the pool acid...
    Started by Leo1211‎, 06-04-2014 02:38 PM
    06-06-2014 01:42 PM Go to last post
  13. DE Filter Pressure Question
    Hi. Long time lurker, First time poster... I have a Hayward 48 DE filter on IG, salt water pool. It's still a little cold in NJ, but have had...
    Started by impnst8‎, 06-05-2014 10:41 AM
    06-06-2014 01:19 PM Go to last post
  14. new to PF and I'm not a good pool owner.
    Hi All, South TX resident here...we have a concrete in ground pool which was effectively a frog pond. The house and pool are approximately 35...
    Started by m06w41‎, 05-25-2014 03:42 PM
    06-01-2014 09:34 PM Go to last post
  15. Diluted ph test
    Ok, this might be a dumb question, but here goes... When doing a diluted ph test (for example when fc is over 10ppm), the instructions are to dilute...
    Started by Themadczar‎, 05-20-2014 12:55 PM
    05-30-2014 09:19 PM Go to last post
  16. Intermatic Pool Timer Wiring
    I have a three wire electrical plug setup and need to connect it to the timer. The instructions are on the door panel but I don't understand them. ...
    Started by sjeffers01‎, 05-10-2014 01:42 AM
    6 Pages
    1 2 3 ... 6
    05-28-2014 04:30 PM Go to last post
  17. clarification
    Hi Ben, No need to post this; I just want to clarify that I had no interest in building my own wood-burning heater, but was looking for reviews of...
    Started by alisonquilts‎, 05-25-2014 11:11 PM
    05-26-2014 12:06 AM Go to last post
  18. Chlorine and PH too low
    I just received the Taylor K2006 test kit I purchased from Amazon (via link). My chlorine test results were 1.0 ppm FC and .4 ppm CC. I have a...
    Started by sjeffers01‎, 05-17-2014 09:27 PM
    05-25-2014 11:54 PM Go to last post
  19. opinions sought on wood-burning pool heaters
    Does anyone have any experience with wood-burning pool heaters? I am intrigued by the idea (and I have a lot of "free" wood, thanks to some awful...
    Started by alisonquilts‎, 05-25-2014 09:52 PM
    05-25-2014 10:56 PM Go to last post
  20. High PH, Low TA
    Ok...so I am having a struggle. Finally got my pool clear and am having to constantly add muratic acid to my pool to keep the PH under control. It...
    Started by Dad2handz‎, 05-19-2014 03:52 PM
    05-21-2014 11:03 PM Go to last post
  21. Newbie getting a pool with a question
    I'm having a IG pool installed in July and was wondering if there is anything that I would need or make my life easier to owning a pool. It's a...
    Started by suzuki98‎, 05-16-2014 09:31 PM
    05-21-2014 11:02 PM Go to last post
  22. What chlorine level to shock -- now that half my CYA is gone
    My appologies if this is the wrong place to post this. I just recently became a subscriber though I've been registered for over a year. I took...
    Started by JimK‎, 05-10-2014 03:58 PM
    6 Pages
    1 2 3 ... 6
    attaboy, pix2fix, sticky, sticky-cya-lost, sticky-de-filter, sticky-winterize
    05-19-2014 11:10 PM Go to last post
  23. 16 year old sand filter
    My Hayward S-244T sand filter will be celebrating its 16th birthday this summer. I've never replaced or cleaned the sand since it was installed,...
    Started by GaryK‎, 05-16-2014 05:15 PM
    05-17-2014 06:08 PM Go to last post
  24. community pool just does not get clear!
    40,000 gal. inground pool, pH 7.4, FC 10, CC 0.5, TA 100, CYA 30. Tests done with Taylor K-2006. We tried to turn our green swamp into a clear pool...
    Started by Stierchen‎, 05-06-2014 12:14 PM
    2 Pages
    1 2
    05-13-2014 07:50 PM Go to last post
  25. Thank You!
    Just wanted to say what an incredible resource this site is. It turns out that I have no unique pool problems after all. I was able to find answers...
    Started by runtgh‎, 05-09-2014 04:01 PM
    05-13-2014 11:33 AM Go to last post
  26. Angry Overwhelmed
    Trying to test pool for first time. Very good circulation. Testing as far down as I can reach. Not sure what readings are telling me. Using K-1000...
    Started by wilsol4‎, 04-27-2014 05:35 PM
    3 Pages
    1 2 3
    05-04-2014 09:06 AM Go to last post
  27. Hydraulic changes due to pipe upgrade
    My pool operates with a Sta-Rite Dura-Glas (P2RA5F-182L) pump and a Hayward Star Clear cartridge filter (C1200). The pump is fed by three (3) 1 - 1/2...
    Started by nefretrameses‎, 05-02-2014 07:59 PM
    sticky-piping
    05-03-2014 06:01 PM Go to last post
  28. Newbie - with cloudy pool
    Hi all! We have had our pool for about 5 years. It is a True L shape vinyl liner pool that is 16x36x41 in size with a deep end of 9 feet. We went...
    Started by Dad2handz‎, 04-16-2014 02:41 PM
    2 Pages
    1 2
    05-03-2014 05:36 PM Go to last post
  29. Question Ready-Set-GO, almost!
    OK. New liner is in. Pool has been filled. Pump is being replaced. Pool water has been sitting for about a week, due to problem after problem with...
    Started by wilsol4‎, 04-25-2014 12:46 PM
    04-25-2014 04:31 PM Go to last post
  30. Thanks Ben & co
    Thanks for setting up the subscriber forum.
    Started by robbym70‎, 03-25-2014 11:05 AM
    03-25-2014 11:20 AM Go to last post
+ Post New Thread
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
