+ Post New Thread
Threads 1 to 30 of 60
Forum: -- Subscriber Posts --
Initial forum for subscriber posts, so their questions get priority attention.
  1. Sticky Thread Sticky: New Directions for PoolForum in 2018 (in revision)
    __________________________________ What’s been the problem? There are several, including personal ones I am not going to explain, but a major...
    Started by PoolDoc‎, 04-09-2018 03:52 PM
    09-30-2018 07:41 AM Go to last post
  1. pH & Chlorine Testing Meters - Which ones ?
    Hi All. Does anyone (BEN ?) have recommendations for digital testing meters for pH and Chlorine/Chloramines? I would rather spend twice as much...
    Started by pratzert‎, 06-15-2019 05:41 PM
    06-15-2019 05:41 PM Go to last post
  2. Chlorine Dry Bleach
    Found a product called Chlorine Dry Bleach? Active Ingredient is Sodium Dichloroisocyanurate, dihydrate 5-15% per SDS. Can't see what inactive...
    Started by paigemetoo‎, 05-31-2019 05:35 PM
    05-31-2019 05:35 PM Go to last post
  3. Keeping the Water Warm
    I have a 32 x 16 AG pool and live in western PA. When we installed it the surrounding trees were much smaller than they are now. Hence, the sun no...
    Started by CoffeeBean‎, 10-25-2018 04:12 PM
    10-27-2018 01:30 AM Go to last post
  4. Unhappy Not able to access my original thread. Am I locked out?
    Pool Doc, I want to reply to my original thread in order to reply to your directions. Do you know why I am locked out? Are you able to tell me...
    Started by Mirandy‎, 09-28-2018 09:59 PM
    arizona pools
    09-29-2018 08:42 AM Go to last post
  5. Just subscribed...
    Ben et al: Great website, just recently started maintaining my own pool, just like anything else in life, you tend to appreciate what you work...
    Started by Nomorepoolguys‎, 04-26-2015 12:13 PM
    04-26-2015 12:13 PM Go to last post
  6. Valve actuator not working as programmed
    I have a Compool CP3400 controller. Freeze guard activated last evening. However, when alternating to spa, only the suction valve opened. The...
    Started by BIGOH‎, 11-18-2014 09:25 PM
    11-18-2014 09:25 PM Go to last post
  7. New User- Hello thanks for accepting me :)
    First a question- I'll post my problem on another post tomorrow. I filled out my POOL PROFILE after I registered ( like your instructions told me to...
    Started by sweepmeup‎, 10-30-2014 09:30 PM
    11-01-2014 10:20 AM Go to last post
  8. Borates for a 10k gal pool
    How many pounds of ProTeam Supreme Plus for a 10,000 gallon IG gunite pool ? Thanking you in advance, shotgun
    Started by shotgun‎, 06-24-2014 10:10 AM
    10-21-2014 10:17 PM Go to last post
  9. Question Oil sheen clean - looking for thoughts/ideas...
    Hi All, Looking for ideas on cleaning up a light oil (mineral oil) sheen on my pool water surface. I have used ScumBalls with some success and I...
    Started by SunnyOptimism‎, 10-13-2014 01:37 PM
    2 Pages
    1 2
    10-17-2014 08:07 PM Go to last post
  10. Chlorine tabs w/o CYA
    Can they be had? I like the convenience of the dispenser, but don't want to get the CYA levels too high. .
    Started by zz28zz‎, 09-03-2014 04:35 PM
    3 Pages
    1 2 3
    10-17-2014 07:18 PM Go to last post
  11. Question pool balance before closing?
    My pool is empty, freshly painted concrete bottom, allowing to cure for several days. My question is, What should my numbers be to balance pool . How...
    Started by FNC1962‎, 09-20-2014 09:32 AM
    3 Pages
    1 2 3
    10-14-2014 06:57 AM Go to last post
  12. Cool Just saying Hi as a newbie subscriber
    Mods - please move if this post is not in the appropriate forum. Just wanted to post a "Hello!" as a new subscriber! So far being on PF has been...
    Started by SunnyOptimism‎, 10-06-2014 06:35 PM
    10-07-2014 06:48 PM Go to last post
  13. Clear, but no chlorine???
    Hello! I ama fairly new pool owner (July 2012) and have a pool waiter problem that no one so far has a solution to! Stumbled across this website...
    Started by mary jo‎, 08-06-2014 08:19 PM
    23 Pages
    1 2 3 ... 23
    09-15-2014 01:05 PM Go to last post
  14. Plaster is like Sandpaper
    Hello All, So far I have done everything requested from newbies. I have subscribed, liked you on Facebook, and filled out the pool form and ordered...
    Started by Mikes Pool‎, 07-10-2014 02:21 PM
    3 Pages
    1 2 3
    09-09-2014 06:08 PM Go to last post
  15. What to do with old MA?
    Last season I seem to have found the sweet spot in my pool chemistry where pH rise is no longer an issue with my SWCG, thanks to great info found on...
    Started by JimK‎, 08-31-2014 12:25 PM
    08-31-2014 08:53 PM Go to last post
  16. BioGuard balance pak 100
    We finally have the new pool finished and operational. Started the pump up on 14 Aug and PB added 7 qts of acid and 2 qts scale inhibitor. I didn't...
    Started by jmarty462‎, 08-18-2014 08:49 PM
    2 Pages
    1 2
    08-28-2014 01:10 PM Go to last post
  17. Issue installing new light
    Originally posted in new users area. Upgraded membership so I could post over here: Needed to replace the light fixtures for my 2 pool lights. I...
    Started by zz28zz‎, 08-25-2014 07:21 PM
    08-28-2014 10:44 AM Go to last post
  18. Moved post
    I paid my subscription and was able to post in "Pool equip and operations". My post got moved to here. I got a good reply to my question, so I'm not...
    Started by zz28zz‎, 08-26-2014 01:17 AM
    08-27-2014 12:29 AM Go to last post
  19. Do sand filters need chemical cleaning?
    I just had a "pool guy" tell me that all residential sand filters need to be chemically cleaned once or twice a year to remove gunk like suntan...
    Started by Pappy‎, 08-23-2014 08:57 PM
    08-24-2014 06:24 PM Go to last post
  20. My thread suddenly closed???
    This thread I started was suddenly closed without explanation. http://www.poolforum.com/pf2/showthread.php/25915-Is-main-drain-necessary Was it...
    Started by JimK‎, 08-19-2014 11:19 PM
    08-20-2014 06:30 PM Go to last post
  21. Iron In My Water
    I accidentally left my well water run into my pool overnight several nights ago. I awoke to a mess of brownish green metallic water. I immediately...
    Started by Phenom300‎, 07-21-2014 06:45 PM
    08-16-2014 08:18 PM Go to last post
  22. Hose leaking
    Have a leak from the hose that goes to the booster pump. Have tried sealing with tape to no avail. Tried to tighten the plastic nut at each end. ...
    Started by maggie2712‎, 08-10-2014 10:57 AM
    08-10-2014 10:57 AM Go to last post
  23. New Pool Construction by Owner - Equipment help!
    Note: I also posted this question the newbies new post section, before I noticed there was a "subscriber section". So I've decided to take on the...
    Started by Lsanc‎, 07-29-2014 11:28 AM
    3 Pages
    1 2 3
    08-07-2014 09:14 PM Go to last post
  24. Not a good day!
    Well this season has not been a good one in many ways. Pool pump had to be replaced, had to have most of my plumbing replaced and a very nasty...
    Started by maggie2712‎, 08-07-2014 04:08 PM
    08-07-2014 04:40 PM Go to last post
  25. Sand everywhere...pump dead:(
    Came home from a weekend away to a pool that was drained below the intake, sand all around the filter on the ground and a dead pump...uggg! We...
    Started by paigemetoo‎, 07-27-2014 08:44 PM
    07-28-2014 07:21 PM Go to last post
  26. Cloudy water for about 10 days.
    I have a 21' X 43' oval AG, 30K gals. I have a Millennium cartridge filter system with a 2 speed Waterway pump. I use the BBB method. For the last...
    Started by tnt69‎, 07-25-2014 10:51 AM
    07-28-2014 10:24 AM Go to last post
  27. New house, unwinterized pool
    This is what I know: 18'x36' IG, vinyl liner,4.5' to ~9.5'= 30k gallons?, unwinterized tagelus sand filter TA 60D, pump is missing in action, as is...
    Started by poms302‎, 06-12-2014 05:14 PM
    07-23-2014 10:42 AM Go to last post
  28. New pool owner, trying to get my chemicals balanced
    Hey everyone, I'm a new homeowner and am new to maintaining a pool. I've recently taken 2 semesters of 100-level college chemistry and a 300-level...
    Started by mitchryan912‎, 07-02-2014 11:46 AM
    6 Pages
    1 2 3 ... 6
    07-21-2014 12:21 PM Go to last post
  29. Question pool chart
    How do I find my pool chart? I also need to edit since I should have 2 pool charts. first one is from previous home. Thanks
    Started by FNC1962‎, 07-15-2014 06:43 AM
    07-17-2014 08:36 AM Go to last post
  30. Question Disappearing chlorine
    My pool is an in ground concrete with 20,000 gallons built in 1974. I have had no major problems in maintaining chlorine levels till now. In Oct 2013...
    Started by arjayh‎, 07-01-2014 02:45 PM
    07-16-2014 10:35 AM Go to last post
+ Post New Thread
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 15 replies or 150 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
