+ Post New Thread
Page 8 of 13 FirstFirst ... 6 7 8 9 10 ... LastLast
Threads 211 to 240 of 372
Forum: Pool Chemistry for Intex-type Pools
Swimming pool chemistry and water care for Intex pools, and other small above ground pools WITH a pump and filter, between 1,000 and 12,000 gallons
  1. Sticky Thread Sticky: Super-simple recipe for Intex type swimming pools
    Super Simple Pool Chemistry Recipe -- for Intex-type pools with a pump and filter, 12 feet in diameter, or larger -- -- for smaller pools and...
    Started by PoolDoc‎, 06-20-2012 03:42 PM
    07-07-2018 08:22 AM Go to last post
  2. Sticky Thread Sticky: FAQs & Guides: Intex-type Pool Chemstry
    _____________________________________________ FAQs & Guides: Intex-type Pool Chemstry Super Simple Recipe for Intex-type Pools More info:...
    Started by PoolDoc‎, 05-28-2018 02:27 PM
    05-28-2018 02:27 PM Go to last post
  3. Sticky Thread Sticky: Super-simple Recipe: Kits, Chemicals, Tools
    More information: Getting an OTO kit: + Get a cheap OTO (yellow drops) / phenol test kit or, better,a HTH 6-Way Test Kit from Amazon or...
    06-24-2014 03:25 PM Go to last post
  1. Calcium Hardness in in vinyl pools?
    I seer that adding calcium to concrete pools helps to prevent concrete erosion but isn't needed for vinyl pools. Swimming Pool Secret #3 "If you...
    Started by abru88CJ‎, 03-23-2013 11:24 AM
    03-29-2013 01:56 PM Go to last post
  2. Help Pool Green
    So my neighbors called the County because my pool is green. It is a Intex 15X48. So far I have added a gallon of liquid chlorine, 1 PM Yesterday and...
    Started by resapre‎, 09-19-2012 11:49 AM
    09-19-2012 11:43 PM Go to last post
  3. Unhappy brown water AGAIN
    Hello, We are having a very hard time with our new pool. The specifics are below. This pool is inside a conservatory, fiber glass walls and roof,...
    Started by retyler‎, 09-09-2012 06:46 PM
    2 Pages
    1 2
    09-14-2012 11:24 AM Go to last post
  4. Question Cya testing
    Hi, Quick question. I added one lb of 99% (Leslie's) CYA on Monday and then another lb on Tuesday. I just performed the CYA test and couldn't...
    Started by RedwingT‎, 08-03-2012 09:48 PM
    3 Pages
    1 2 3
    09-14-2012 07:00 AM Go to last post
  5. DiChlor OverKill
    --- Should I start afresh or work to correct this chemically? --- I've been devouring the materials at PoolSolutions and creating my own portable...
    Started by Stanziaa‎, 09-10-2012 05:04 PM
    09-10-2012 09:17 PM Go to last post
  6. Question Chem log, to see....
    ...if I'm doing it right. Test results this AM with HTH 6-way: Chlorine .75 pH 7.6 TA 260 TH 250 ...
    Started by Charlie_R‎, 07-05-2012 09:28 PM
    8 Pages
    1 2 3 ... 8
    pix
    09-05-2012 09:16 PM Go to last post
  7. Where did my CYA go and when do I cover my pool?
    Hurrah, my first real post here on PF! Got my Taylor 2600 test kit today, and here are my first results: FC: 2.5 CC: 0 PH: < 7.0 (Base Demand =...
    Started by poolf7665‎, 08-29-2012 07:56 PM
    08-29-2012 11:04 PM Go to last post
  8. pool newbie with cloudy water
    I have a 15' Intex Easy Set, filled with well water (abt 5,000 gal). I used a hose filter (10" Bobby by Hayward) I bought at a local pool store,...
    Started by wackster‎, 07-22-2012 09:17 PM
    4 Pages
    1 2 3 ... 4
    bmp-track
    08-26-2012 07:16 PM Go to last post
  9. Closing and taking down the pool
    Well it's getting near the end of the Summer and I need to plan on taking my pool down for the Winter. (I don't think I can leave it up all Winter...
    Started by NJPaul‎, 08-23-2012 04:19 PM
    08-23-2012 04:19 PM Go to last post
  10. Pool Filter is Green, could I have algae?
    Last week, I had something that looked like red dirt on the bottom of my pool. It wouldn't vacuum up, so I brushed it off. After I had it all...
    Started by ac1007‎, 08-16-2012 12:07 AM
    2 Pages
    1 2
    08-20-2012 07:01 PM Go to last post
  11. First time AG pool owner
    Hi, we've been using our new 18' AG inflatable pool for a few weeks now. It's filled with cloramine city water. We are treating the pool before...
    Started by Wmvdligt‎, 08-13-2012 01:40 AM
    08-14-2012 11:04 AM Go to last post
  12. Can't keep chlorine levels up
    I have a 18 X 52 round Intex pool. I had a problem with algae and my water was green. I bought HTH Pool shock and used that and 2 days later the pool...
    Started by resapre‎, 08-12-2012 11:04 PM
    08-13-2012 04:37 PM Go to last post
  13. New User
    Hi. I am a new user. We are in Central Texas. We have an Intex AG 12'x3' pool. Today we have emptied the pool and are re-filling with fresh water. I...
    Started by hazellee116‎, 08-12-2012 01:17 PM
    08-13-2012 03:18 PM Go to last post
  14. Unhappy Intex 15x48 with algae
    I have an Intex 15' x 48" with an algae problem and the stock pump that just sucks (or lack there of). I'm heading out tonight to pick up my BBB...
    Started by DSeese‎, 07-12-2012 06:31 PM
    2 Pages
    1 2
    08-13-2012 02:19 PM Go to last post
  15. New pool owner
    Greetings all! Proud new owners of an Intex 15" AG pool currently set up in a temporary location in the back yard. It was filled with well water but...
    Started by Gomez5693‎, 08-06-2012 11:11 PM
    2 Pages
    1 2
    08-12-2012 08:36 PM Go to last post
  16. Fighting mustard algae, too
    PoolDoc - Please excuse me for "barging in" on this thread, but I need help with mustard algae also. My initial contact was regarding your wonderful...
    Started by southside‎, 08-10-2012 10:58 AM
    2 Pages
    1 2
    08-12-2012 07:01 PM Go to last post
  17. Calculating dosage for borax and dichlor powder for Intex easy set pool
    Hi, I've just resurrected my 15ft Intex Easy Set pool and saw the page on the 7-day chemical start-up, etc, and I don't see any info on amounts for...
    Started by swimg‎, 08-10-2012 06:51 PM
    08-11-2012 10:53 PM Go to last post
  18. New member
    New member here... used this forum and the pool calculators all the time with our 10' easy set pool for the last 4 years (and for years before that...
    Started by 7sanders‎, 07-02-2012 01:44 PM
    3 Pages
    1 2 3
    08-10-2012 12:27 PM Go to last post
  19. Vogue Zenith HTH 6 way test results.
    Ok im not sure if my pool is considered an intex type pool. I am about to start doing the BBB method as soon as my initial startup chemicals are used...
    Started by jrock29‎, 08-09-2012 08:15 PM
    08-09-2012 08:33 PM Go to last post
  20. Angry Algae problem!!! Can't get rid of green in my pool!! Please help!
    I have a Intex 15ft by 4 ft deep pool. It's the one with the metal poles. We had the same problem last year, so I got a bigger pump. Instead...
    Started by Teia Brady‎, 08-09-2012 05:15 PM
    08-09-2012 06:20 PM Go to last post
  21. Intex type pool?
    We have a pool that's like an Intex but is sturdier and can be left up all year. We run a regular sandfilter to filter it. As I was reading through...
    Started by grammy57‎, 08-04-2012 06:27 PM
    08-08-2012 10:38 AM Go to last post
  22. No question yet, just thanks
    I don't have a question just yet, as I've been reading the site and have created a list of supplies to get tonight at Walmart. From what I've read...
    Started by cditty‎, 08-06-2012 01:45 PM
    08-07-2012 09:21 PM Go to last post
  23. Test Results...I think!
    I finally got a test kit. Those little buggers aren't cheap. We have a SWG but I am not using it until I can get things figured out. Is that okay? ...
    Started by Dw4scoobydoo‎, 07-30-2012 10:25 PM
    08-07-2012 09:29 AM Go to last post
  24. Newbie here! Already filled my intex 15x36 pool with water (Oops!)
    I read your bleach/borax treatment suggestion a little too late. My pool is just about filled with 2800 gallons of well water. What is my next...
    Started by joolz1226‎, 07-26-2012 05:20 PM
    08-03-2012 07:40 PM Go to last post
  25. Chlorine troubles
    Hello, newbie here trying to get things right in our pool. We set up our pool a little over 2 weeks ago and I can't keep chlorine in it now. ...
    Started by Cowtown‎, 08-01-2012 11:22 AM
    08-02-2012 10:04 AM Go to last post
  26. Smile I'm back! but with a different pool.
    Greetings everyone! This year we have a different pool, a different pump, filled from a different water source (still well water though) so...
    Started by swamp mistress‎, 07-12-2012 12:44 PM
    3 Pages
    1 2 3
    08-01-2012 11:29 PM Go to last post
  27. Thanks!!
    I just wanted to say Thanks!! for all the help. I've been reading this forum and have gotten educated in care of my pool. I have even referred...
    Started by sun and water‎, 08-01-2012 04:12 PM
    attaboy
    08-01-2012 06:01 PM Go to last post
  28. New Intex owner from Texas
    Hi! Well, this is my story: This is the equipment I have - Intex 18'x48" Metal Frame above ground pool, 6,423 gals. Intex Sand Filter Pump,...
    Started by Rockwall‎, 05-19-2012 09:55 PM
    3 Pages
    1 2 3
    08-01-2012 02:43 PM Go to last post
  29. Water Question
    The water we use in our pool is treated water, they have a reverse osmosis plant where our water comes from, so how could our pool possibly show that...
    Started by pool_newbie76‎, 07-17-2012 05:39 PM
    2 Pages
    1 2
    07-31-2012 11:02 PM Go to last post
  30. Bleach Dose amount when filling
    First off just want to thank all in advance for all the information and knowledge I have already acquired and will acquire in the future. This site...
    Started by PaPoolNewB‎, 07-31-2012 10:34 AM
    07-31-2012 12:10 PM Go to last post
+ Post New Thread
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
