+ Post New Thread
Page 13 of 13 FirstFirst ... 3 11 12 13
Threads 361 to 372 of 372
Forum: Pool Chemistry for Intex-type Pools
Swimming pool chemistry and water care for Intex pools, and other small above ground pools WITH a pump and filter, between 1,000 and 12,000 gallons
  1. Sticky Thread Sticky: Super-simple recipe for Intex type swimming pools
    Super Simple Pool Chemistry Recipe -- for Intex-type pools with a pump and filter, 12 feet in diameter, or larger -- -- for smaller pools and...
    Started by PoolDoc‎, 06-20-2012 03:42 PM
    07-07-2018 08:22 AM Go to last post
  2. Sticky Thread Sticky: FAQs & Guides: Intex-type Pool Chemstry
    _____________________________________________ FAQs & Guides: Intex-type Pool Chemstry Super Simple Recipe for Intex-type Pools More info:...
    Started by PoolDoc‎, 05-28-2018 02:27 PM
    05-28-2018 02:27 PM Go to last post
  3. Sticky Thread Sticky: Super-simple Recipe: Kits, Chemicals, Tools
    More information: Getting an OTO kit: + Get a cheap OTO (yellow drops) / phenol test kit or, better,a HTH 6-Way Test Kit from Amazon or...
    06-24-2014 03:25 PM Go to last post
  1. Do I really need to brush the sides?
    As you can see below, I have a much smaller Intex pool than most of you (don't worry, I plan on going up to the next model each year as I get more...
    Started by SafetyBob‎, 05-09-2012 11:25 AM
    05-09-2012 07:37 PM Go to last post
  2. help for dummies needed
    My second year with intex pool 24 x 52. First year tried pool supplies from walmart and it was total mess This year started with testing fresh water...
    Started by alpom‎, 05-07-2012 01:47 PM
    05-08-2012 02:07 PM Go to last post
  3. Angry Light green water
    We have an Intex 16'x32'x52" pool. I use a sand filter and cartridge filter because we use a salt water generator. For the winter we left about 3' of...
    Started by Huskerdee‎, 03-22-2012 09:54 AM
    5 Pages
    1 2 3 ... 5
    04-08-2012 10:29 PM Go to last post
  4. Raising Chlorine Making Water Green
    Been using BBB method for a few months successfully. Tree debris and pollen began to fall and I let chlorine level drop too low. There was no algae...
    Started by Cookieman‎, 04-01-2012 03:45 PM
    04-06-2012 11:14 PM Go to last post
  5. Opening Pool issues
    I am trying to open our pool this year and having issues. We have a 24ft 48inch Intex Ultra Frame pool. The pool pump is a brand new Intex pump and...
    Started by wolvskiss‎, 03-26-2012 05:26 PM
    03-26-2012 06:33 PM Go to last post
  6. Pool pH is at the "ideal" level, but alkalinity is super high
    First time pool owner here, got one of those Intex metal frame pools. Going on my 3rd week of trying to figure out chemicals... finally got the pool...
    Started by mindleak‎, 03-21-2012 01:16 PM
    2 Pages
    1 2
    intex, setup, startup
    03-25-2012 03:05 AM Go to last post
  7. Pop up pool
    I recently purchased a pop up pool for my family. There is no instructions for what chemicals to add in the beginning. It just says that I need to...
    Started by popuppool11‎, 06-12-2011 09:28 AM
    intex, sticky
    03-14-2012 06:32 AM Go to last post
  8. Intex type pool filled with manganese & iron
    Hi there... hoping that someone out there can provide some help & advice on our pool water issues. I've been reading different threads for the last...
    Started by JustLeigh‎, 07-19-2011 08:51 AM
    intex, metal filled pools, metals, startup, sticky, well water
    07-22-2011 11:27 AM Go to last post
  9. Clear Pool after 48 hours of filling
    Woo-hoo *doing a little happy dance* I thought I'd post a positive story about removing iron from your pool :) I bought an 18ftx48" Intex above...
    Started by kristen‎, 06-18-2011 08:32 PM
    sticky
    06-26-2011 09:03 AM Go to last post
  10. Post CYA Test is Clear
    Hello! I have an Intex 15' x 42" easy set pool (inflatable ring kind). I have been having issues with my CYA testing (I have tested twice since...
    Started by earlybird‎, 06-12-2011 03:24 PM
    06-12-2011 04:24 PM Go to last post
  11. Unhappy got new 24x5 round intex pool need help with water. Sandy water..help
    I just purchased a intex 24 x 5 swimming pool. I filled the pool using my water well, water comes from an artesian aquifer that has amazing water....
    Started by iwannaswim‎, 06-08-2011 12:57 PM
    intex, sticky, well water
    06-08-2011 08:42 PM Go to last post
  12. upgrade 20x4 intex?
    Hi all! I'm new here and am really digging this pool building stuff. Trying to add a little efficiency to my game plan. Found a large Hayward sand...
    Started by jdsapp‎, 05-23-2011 12:53 PM
    entrapment, pix, sticky
    05-24-2011 07:05 AM Go to last post
+ Post New Thread
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
