+ Post New Thread
Page 6 of 30 FirstFirst ... 4 5 6 7 8 16 ... LastLast
Threads 151 to 180 of 900
Forum: Pool Startup, Shutdown, & Winter Operation
Spring startup; new pool startup; fall shutdown & winterization.
  1. Sticky Thread Sticky: Closing an IG pool for the Winter
    Edit 12 Oct 06: Sorry I haven't gotten around to adding the pics I promised. The forum won't let me add any more attachments. Until this is resolved,...
    Started by Poconos‎, 09-18-2006 10:16 AM
    09-18-2006 10:16 AM Go to last post
  2. Sticky Thread Sticky: Closing an AG pool for the winter
    This is the procedure I use when preparing my AG pool for closing. I actually cover it pretty early in the fall before all the trees start...
    Started by Watermom‎, 09-04-2006 10:51 AM
    09-04-2006 03:03 PM Go to last post
  3. Exclamation Sticky Thread Sticky: FAQ: Common Spring Startup Errors
    This FAQ as been expanded, and moved to www.poolsolutions.com/gd/spring-swimming-pool-startup-problems.html Ben / PoolDoc
    Started by PoolDoc‎, 03-29-2006 09:59 AM
    03-29-2006 09:59 AM Go to last post
  1. Chlorine Lock? Draining pool only option?
    Have a in ground gunite pool 30,000 gallons, that we've owned for 15 years. Just opened the pool last week, it was pretty clear with just some leaf...
    Started by thekabuki‎, 05-19-2013 03:58 PM
    05-23-2013 06:56 PM Go to last post
  2. Spring Start Up Numbers Issue
    Hi all, Last year had a late start to the season(End of August) but a successful one due to everyone's help on here using the BBB method after the...
    Started by PaPoolNewB‎, 05-22-2013 06:17 PM
    05-22-2013 11:38 PM Go to last post
  3. New to this forum
    New pool, concrete wall with vinyl liner, spa, salt generator and heat pump. Going to need help I am sure! Glad to be here!
    Started by rburr‎, 05-18-2013 06:54 PM
    05-20-2013 11:36 PM Go to last post
  4. Should I shock my pool upon opening, even if there is no algae build up?
    Hi. My pool is a 20x40 in-ground with 40,000 gallons of water and a vinyl liner. I'll be opening it on the weekend. When I closed it in October,...
    Started by Racker‎, 05-15-2013 05:19 PM
    05-15-2013 05:34 PM Go to last post
  5. multivalve question for spring startup
    2 quick question for spring startup concerning my multivalve port: 1) I changed my sand this winter. I know I have to prime my pump. Can I...
    Started by Txboynjgirl‎, 05-09-2013 03:22 PM
    05-09-2013 03:22 PM Go to last post
  6. spring startup mutivalve question
    I haven't opened up my pool for the spring. I know it is going to be solid green. I replaced the sand in my sand filter. I know you are suppose to...
    Started by Txboynjgirl‎, 05-08-2013 03:41 PM
    05-08-2013 03:41 PM Go to last post
  7. Question New Liner installed, chem #s
    Hi all, I had a new liner installed a week or so ago. I could use some advice on getting the chemistry right. 2 days of testing after installer...
    Started by FNC1962‎, 04-23-2013 07:29 PM
    04-23-2013 09:20 PM Go to last post
  8. Opened pool
    Just opened my pool. I've been here for a year now and was hoping some of the vets would take a look at my #s and offer any advice they think might...
    Started by 392papa‎, 04-20-2013 04:27 PM
    04-21-2013 08:27 AM Go to last post
  9. Spring Start U
    Is there a "sticky" or thread that talks about the steps to starting up a pool? We didn't cover this past winter and our pool is very green. We just...
    Started by my_youngminds‎, 04-15-2013 10:10 PM
    04-18-2013 07:03 PM Go to last post
  10. pump kicking off CFI
    We're opening our pool and when we turn the switch for the pump, it's kicking off the CFI. We replaced the CFI and it's still kicking it off. (so in...
    Started by koagirl‎, 04-11-2013 06:54 PM
    04-12-2013 11:34 AM Go to last post
  11. High AK, Is it ok to start with the bleach.
    Brought my water level up. Let it pump run for a day. Tested Ak (first step I think) And it came out pretty high 120 ppm. Do I need to get it...
    Started by bssage‎, 04-08-2013 06:33 PM
    04-10-2013 04:11 PM Go to last post
  12. Need advice on pre-pool spring maintenance.
    heres my pickle. every year i drop the ball and open a green monster pool. i try to chlorinate it before i remove my mesh cover every week but i...
    Started by pbotz2000‎, 04-03-2013 12:40 PM
    04-10-2013 10:15 AM Go to last post
  13. Opening the pool a little early. Here are my test results so far.
    FC- 3ppm TC- 3ppm CC=0 pH- 8, I added 5 drops of R-0005 to get it down to 7.4 TA- 140ppm CH- 360ppm CYA- 100ppm I added about 3 quarts of...
    Started by bri3180‎, 02-19-2013 12:24 PM
    02-19-2013 12:24 PM Go to last post
  14. Timer for Pool Cover Pump
    OK, I'm old, forgetful, distracted or something. The cover on my pool is what I refer to as a "Glad Bag" cover. Basically a huge tarp. I have a $70...
    Started by nelsongg‎, 02-15-2013 07:05 AM
    02-15-2013 07:05 AM Go to last post
  15. drain water from the skimmer?
    Hi. I closed my pool in October. It's an inground pool with a vinyl liner, so I left the water level up and blew the air out of the lines with a...
    Started by Racker‎, 11-28-2012 09:54 PM
    12-03-2012 07:51 PM Go to last post
  16. draining pool question/s
    hello. i know responses may be slow right now since summer is over. anyway, any help will be appreciated. i need to drain my pool so i can slap on a...
    Started by fhorta‎, 11-22-2012 02:27 PM
    12-03-2012 07:42 PM Go to last post
  17. IG pool closing questions
    I have read the sticky and still have questions. In particular, the pool discussed in the sticky does not have a main drain so that is not discussed...
    Started by gogolion‎, 09-12-2012 04:02 PM
    11-29-2012 01:02 PM Go to last post
  18. Does anyone RAISE their water level to close?
    I am wondering if anyone on the forum has ever tried to plug their skimmer with an aquador & plug the return and then raise the water level up to a...
    Started by tnt69‎, 11-11-2012 04:18 PM
    11-28-2012 10:54 PM Go to last post
  19. Pool water level / winter cover question
    Hi, I just had a fiberglass pool installed this past summer, and this is my first winter with it. I had the winter safety cover installed about a...
    Started by Rick H‎, 11-15-2012 01:01 PM
    11-24-2012 05:46 PM Go to last post
  20. Best Way to Winterize Filter/Valve
    I have a Tagelus sand filter with a Pentair Hi-Flow valve. I followed the manual's instructions precisely to winterize the unit. This invlovled...
    Started by bordersong67‎, 11-19-2012 03:42 PM
    11-20-2012 01:48 PM Go to last post
  21. Pool Cover with No Puddles to Pump
    I've received so much help from the experts in this forum I thought I'd take a moment to share a solution that I developed with with the forum....
    Started by Steveromo‎, 11-04-2012 11:02 AM
    11-08-2012 09:01 PM Go to last post
  22. Closing Pool :(
    Closing The pool for the winter...way to late(cinci OH here). Had a the best year ever thanks to your help. I just wanted to post my final readings...
    Started by 392papa‎, 10-20-2012 04:29 PM
    10-22-2012 09:33 PM Go to last post
  23. Post Pool Closing Concerns
    Its time to close my AG intex 32'x16'x52" 14,365 gal. pool. My ALK readings is and have been consistent at 140 , my pH is 8.0 and has been...
    Started by YvonneSEU‎, 10-19-2012 11:36 PM
    10-22-2012 08:23 PM Go to last post
  24. wind and a pool cover
    I put a cover on my AG pool, winched it down, put tons of clips on it, put some water on the top.....it is still blowing around like a parachute. So...
    Started by bjaeram‎, 10-06-2012 02:15 PM
    10-18-2012 11:29 AM Go to last post
  25. Can I leave eyelet uncapped?
    Last winter I drained water to below eyelet and then capped the eyelet and covered the skimmer with plate and gasket before covering the pool....
    Started by Steveromo‎, 10-10-2012 09:26 PM
    10-18-2012 08:44 AM Go to last post
  26. How much closing a pool do I need to do?
    I read about draining water, plugging returns etc..and I was concerned I would not do it correctly. We called the local pool store to get an...
    Started by tokmom‎, 08-30-2012 12:49 PM
    10-18-2012 07:55 AM Go to last post
  27. Closing....when to add algaecide?
    I read not to add algaecide right after shocking because the chlorine would break down the algaecide. The article said to shock a couple days before...
    Started by JimK‎, 10-03-2012 10:04 PM
    10-11-2012 07:46 PM Go to last post
  28. Darn. I hate this day.
    By 'this day' I mean the day I finally give up on attempting to keep the pool warm enough to swim and accept the fact that my swim season is over....
    Started by Watermom‎, 09-26-2012 04:39 PM
    10-10-2012 11:39 PM Go to last post
  29. Closed Pool this past weekend
    I closed my pool this past weekend. I have to say it was alot of work, though most of it was double, triple, quadruple checking everything I was...
    Started by ImpalaRob‎, 10-01-2012 06:57 PM
    10-09-2012 10:47 PM Go to last post
  30. Blow out main drain or not?
    Reading some of the threads about pool closing made me realize I've never blown the water out of the main drain pipe since the pool was installed in...
    Started by JimK‎, 10-04-2012 10:52 PM
    10-07-2012 08:54 PM Go to last post
+ Post New Thread
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
