+ Post New Thread
Page 5 of 30 FirstFirst ... 3 4 5 6 7 15 ... LastLast
Threads 121 to 150 of 900
Forum: Pool Startup, Shutdown, & Winter Operation
Spring startup; new pool startup; fall shutdown & winterization.
  1. Sticky Thread Sticky: Closing an IG pool for the Winter
    Edit 12 Oct 06: Sorry I haven't gotten around to adding the pics I promised. The forum won't let me add any more attachments. Until this is resolved,...
    Started by Poconos‎, 09-18-2006 10:16 AM
    09-18-2006 10:16 AM Go to last post
  2. Sticky Thread Sticky: Closing an AG pool for the winter
    This is the procedure I use when preparing my AG pool for closing. I actually cover it pretty early in the fall before all the trees start...
    Started by Watermom‎, 09-04-2006 10:51 AM
    09-04-2006 03:03 PM Go to last post
  3. Exclamation Sticky Thread Sticky: FAQ: Common Spring Startup Errors
    This FAQ as been expanded, and moved to www.poolsolutions.com/gd/spring-swimming-pool-startup-problems.html Ben / PoolDoc
    Started by PoolDoc‎, 03-29-2006 09:59 AM
    03-29-2006 09:59 AM Go to last post
  1. Did I just waste my Polyquat?
    I read a few posts on winterizing so I brushed the pool, raised my chlorine to shock level and put in a quart of polyquat (we have visible algae I...
    Started by Leehicks79‎, 09-29-2013 09:53 AM
    10-10-2013 12:00 PM Go to last post
  2. Power bill. OUCH
    We just moved into the new house about 5 or 6 weeks ago and we'd never had a house with a pool. Just got our first full months power bill and OUCH,...
    Started by DonDon1145‎, 10-08-2013 07:43 AM
    10-10-2013 10:35 AM Go to last post
  3. Any opinions about Winterpill AP71?
    This will be the first year that I winterize without intending to drain the pool in the spring (I had the pool repainted this past spring, so I...
    Started by nilloc‎, 09-27-2013 04:32 PM
    10-08-2013 07:16 PM Go to last post
  4. Trying to close but out of practice - help!
    It's been a couple of years since I posted here. Two since I even opened my pool due to travel (last) and health (this) year. We have a Doughboy...
    Started by CoffeeBean‎, 09-16-2013 10:37 AM
    10-08-2013 04:13 PM Go to last post
  5. Closinq Question w/ Leaky Liner
    I used to have a sunroom over my pool. We just removed the sunroom, so now it is officially an outdoor pool. We have a liner that is leaking, we...
    Started by columbusdan‎, 09-23-2013 03:17 PM
    10-07-2013 03:53 PM Go to last post
  6. I'll try again - need help to balance and close
    I've been a member of the Forum for a long time but haven't been on board for a couple of years. I need some advice and posted the other day. When...
    Started by CoffeeBean‎, 09-17-2013 01:06 PM
    2 Pages
    1 2
    10-06-2013 05:11 PM Go to last post
  7. Blowing Out Lines..Shop Vac Not Working
    I have a 6 hp shop vac and it seems to be under powered for the far skimmer and return, which is about 40-50ft from where I'm blowing. The skimmer I...
    Started by bmlocal175‎, 09-28-2013 02:15 PM
    10-06-2013 03:49 PM Go to last post
  8. Cover equipment to extend life?
    I can't believe in just a few short weeks it'll be time to start thinking about closing for the season. :sad: This year I had to replace my pump...
    Started by JimK‎, 08-30-2013 03:37 PM
    2 Pages
    1 2
    10-06-2013 10:02 AM Go to last post
  9. winterizing
    I am getting ready to winterize my pool here in Pennsylvania. This past spring when I opened my pool it was thick with algae. It is always messy...
    Started by apearso‎, 08-22-2013 06:24 PM
    2 Pages
    1 2
    winterizing
    10-06-2013 09:55 AM Go to last post
  10. closing question
    i replaced my liner this year and had the pool filled by city water. i never could get the cya where it needed to be. i have added stablizer and...
    Started by poolhelp101‎, 09-24-2013 04:18 PM
    10-05-2013 10:47 AM Go to last post
  11. Closing for the winter
    I have a 20x48 intex ultra frame with an intex 2500/gps sand filter. Location is Midwest. Any suggestions on how to winterize? Chemical...
    Started by costo‎, 09-26-2013 09:57 PM
    10-05-2013 10:40 AM Go to last post
  12. Storing bleach outside; decomposition of bleach
    Hi gang. Sorry if this has been covered. I couldn't find it anywhere... I closed my pool for the winter. I have a few cases of bleach left...
    Started by tmess13‎, 10-01-2013 08:28 AM
    10-03-2013 07:24 PM Go to last post
  13. Red face Winterizing options for a small pool in non-freezing climate (California)
    Hi, This is the first year with a house with swimming pool. I have a small size swimming pool, but it is still hard for me to properly manage it....
    Started by notilas‎, 08-30-2013 12:34 PM
    winterizing
    08-30-2013 03:53 PM Go to last post
  14. How do I close an AG Intex pool for the winter?
    Since finding this site in June I have been using the BBB method and it works great! I would like to know what you recommend for closing this type...
    Started by amillionpets‎, 08-29-2013 05:51 PM
    08-29-2013 05:51 PM Go to last post
  15. closing pool removing stairs
    I have had an above ground pool for years and we have always pulled out the stairs. My stairs are heavy big 4 step plastic stairs and it has been a...
    Started by gizmo‎, 08-24-2013 10:24 AM
    08-27-2013 08:58 PM Go to last post
  16. Wind blown dust -- Intex pool Cover ?
    Thank you for all the information on this site. I have 15' Intex metal frame pool and have had little problem with the chemicals. I live in Central...
    Started by Jamiel13579‎, 08-23-2013 05:15 PM
    08-23-2013 05:58 PM Go to last post
  17. Closing pool for winter
    I live in Tennessee and have an AG metal frame pool with a cartridge filter. Could someone pls tell me the steps i need to do to close for the...
    Started by Stephanie34‎, 08-12-2013 10:26 AM
    08-12-2013 10:26 AM Go to last post
  18. Visalia 25k Gallon Filling Now
    Visalia 25k Gallon Filling Now I'm in the process of filling a pool that has been empty for a few years. I'm looking for some help in getting the...
    Started by Fuzz1‎, 08-02-2013 10:18 AM
    08-04-2013 06:36 PM Go to last post
  19. Question Starting from scratch (new water)
    After I install the new liner (soon) I will have to, for the first time ever, start from scratch with water balance. Is there a preferred order of...
    Started by jilted‎, 04-11-2013 05:52 PM
    2 Pages
    1 2
    07-09-2013 06:50 AM Go to last post
  20. New Liner/New Fill From Well
    Unfortunately I have to put in a new liner in our pool so at least I get a fresh start with water chemistry. The pool is 27' round with 48" wall. ...
    Started by jrsdws‎, 06-29-2013 04:08 PM
    07-03-2013 04:01 PM Go to last post
  21. Cleaning up a very dirty pool with a DE filter
    Hi, I'm helping my brother in law out with an inground pool. They just bought the house over the winter and are now in possession of a 16x32 inground...
    Started by jrtredo‎, 06-17-2013 10:28 AM
    06-27-2013 11:48 AM Go to last post
  22. New member, with brand new vinyl liner...
    and hoping to be smarter about all of this going forward! We just filled our pool this weekend (just had a new liner installed), using municipal...
    Started by Verndoggy‎, 06-09-2013 12:05 PM
    sticky
    06-19-2013 01:52 PM Go to last post
  23. 1 Week New Pool
    Hi all! Just had my new construction, pool finished last week, and have a few questions. My builder, says not to use the automated ( tab)chlorinator...
    Started by t-cell‎, 06-18-2013 01:30 AM
    06-19-2013 01:43 PM Go to last post
  24. Opening for Spring
    Hi. I have an in ground gunnite pool, cartridge filter we're going to replace all that this year. But in lieu of paying about $400 for opening our...
    Started by Jess6521‎, 04-12-2013 04:54 PM
    06-16-2013 11:39 AM Go to last post
  25. Post Vinyl pool startup
    Just purchased my Alk and PH for opening. Question, I'm raising my Alk now, next should I adjust my CyA first or total hardness next, both are very...
    Started by Bedwards01803‎, 06-01-2013 02:02 PM
    2 Pages
    1 2
    06-10-2013 07:34 PM Go to last post
  26. Pool girl
    I recently came back to the homestead when my father passed & my mom needed care. I have a L shaped pool. I just replaced the sand filter & new...
    Started by DaddysBabygirl‎, 05-29-2013 08:16 PM
    06-03-2013 10:22 PM Go to last post
  27. Cloudy Water - Advice please!
    Hi All, Looking for advice on how to clear up my cloudy pool water. I've read a lot online and basically all the sites that seem reputable seem...
    Started by TwinDad67‎, 06-02-2013 12:04 PM
    06-02-2013 05:27 PM Go to last post
  28. Initial setup
    I have a 25x13 splash super pool. 10,500 gallons. Just filled it up yesterday for the first time. I am new to pools - so I'm looking at the forum...
    Started by dkdevo‎, 05-27-2013 09:28 PM
    05-29-2013 05:47 PM Go to last post
  29. pH Yellow Out Baking Soda etc
    Boy finding information on pool chemicals is like shopping for laptops. Ask 10 different people for their opinion and you will get 15 different...
    Started by graceland‎, 05-28-2013 09:43 PM
    05-29-2013 04:35 PM Go to last post
  30. Foreclosure Pool
    Bought a foreclosure in February, moved in in April. Inherited a 16'x32' IG pool with shredded cover. Assuming it hadn't been maintained for at least...
    Started by svu22‎, 05-25-2013 05:36 PM
    pix2fix
    05-29-2013 10:37 AM Go to last post
+ Post New Thread
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
