+ Post New Thread
Page 4 of 30 FirstFirst ... 2 3 4 5 6 14 ... LastLast
Threads 91 to 120 of 900
Forum: Pool Startup, Shutdown, & Winter Operation
Spring startup; new pool startup; fall shutdown & winterization.
  1. Sticky Thread Sticky: Closing an IG pool for the Winter
    Edit 12 Oct 06: Sorry I haven't gotten around to adding the pics I promised. The forum won't let me add any more attachments. Until this is resolved,...
    Started by Poconos‎, 09-18-2006 10:16 AM
    09-18-2006 10:16 AM Go to last post
  2. Sticky Thread Sticky: Closing an AG pool for the winter
    This is the procedure I use when preparing my AG pool for closing. I actually cover it pretty early in the fall before all the trees start...
    Started by Watermom‎, 09-04-2006 10:51 AM
    09-04-2006 03:03 PM Go to last post
  3. Exclamation Sticky Thread Sticky: FAQ: Common Spring Startup Errors
    This FAQ as been expanded, and moved to www.poolsolutions.com/gd/spring-swimming-pool-startup-problems.html Ben / PoolDoc
    Started by PoolDoc‎, 03-29-2006 09:59 AM
    03-29-2006 09:59 AM Go to last post
  1. Open pool and green algae on the bottom
    Going into my 3rd year of having an in ground pool. Pool company opens pool and by the way the same company who closed the pool last October and what...
    Started by Ron_M‎, 05-10-2014 03:51 PM
    05-10-2014 04:32 PM Go to last post
  2. Question Too much algaecide in pool
    I put way too much alg. in pool when opening. Now water will not clear up..What can I do? thx
    Started by Earl J‎, 05-07-2014 07:52 AM
    05-08-2014 02:44 PM Go to last post
  3. Can't remove pool return winterizing plugs
    Hello! I am trying to open my in ground pool, but no matter what I do I can't get the return plugs out! ! They are the kind that have a wing nut...
    Started by queenbee53011‎, 05-05-2014 10:51 PM
    05-08-2014 12:22 AM Go to last post
  4. Unhappy Pump Problem - No suction from Skimmer
    I'm a newbie so I can only post here. Hope to get some help from the experienced pool owners. I don't have any suction at all from the skimmer but...
    Started by felic‎, 04-29-2014 01:23 PM
    05-04-2014 06:16 PM Go to last post
  5. Unhappy Chlorine Just Disappears After Shock
    This spring at pool start up my attempts to shock and add 2 gal of 12% liquid chlorine to my 12k gallon vinyl pool have failed. Good news is the...
    Started by JohnnyB‎, 05-02-2014 02:08 PM
    05-02-2014 02:25 PM Go to last post
  6. Closing with "pink slime and white water mold"
    Been using the BBB method several successful years with the help of this forum. Closed the pool (mesh cover) and then found the pink slime/mold in...
    Started by CarolineM‎, 10-21-2013 06:32 PM
    3 Pages
    1 2 3
    amz2fix
    05-02-2014 12:09 PM Go to last post
  7. Pool opening chemicals
    I have an inground 20,000 gallon chlorine pool with a liner. The company that is opening my pool does not add any chemicals when the open it. They...
    Started by rardon74‎, 05-01-2014 09:17 AM
    05-01-2014 09:57 AM Go to last post
  8. Drain and Fill or Treat???
    I just purchased a foreclosure HUD home. The pool is dark green and slimy. It had a lumber and black polyfilm cover over it for liability reasons. I...
    Started by jjl64‎, 04-30-2014 02:28 AM
    04-30-2014 06:52 AM Go to last post
  9. Just right
    Not sure if you all remember the nightmare startup I had last year for my 1st season as a pool owner, but it was very unpleasant. (Swamp, unknown...
    Started by Themadczar‎, 04-23-2014 08:27 PM
    04-29-2014 08:00 PM Go to last post
  10. Is it OK to open my pool in late June instead of May in Iowa?
    I am a first time pool Owner. The reason I want to get my pool opened late is because I will be out of the country for 3 weeks starting end of may...
    Started by tayalm‎, 04-22-2014 04:17 PM
    04-24-2014 06:48 PM Go to last post
  11. Question Chlorine vs Bleach Poll
    I've had my pool for many years. (16x32) Always used granular or 3" tabs.....I don't bother w/ either anymore..Last year I used household bleach.. ...
    Started by Earl J‎, 04-23-2014 11:19 AM
    04-23-2014 08:39 PM Go to last post
  12. Question Meyco winter cover?
    I love the ease of placing in fall and removing in spring..But when I open pool in spring, the water is BLACK and filled w/ algae..Do u have same...
    Started by Earl J‎, 04-23-2014 08:11 AM
    04-23-2014 02:25 PM Go to last post
  13. Just purchased a new above ground Doughboy pool...
    Starting to explore to find the do's and don'ts as we have never had a pool, just community pools.
    Started by Msd5052001‎, 04-19-2014 03:42 PM
    04-23-2014 11:53 AM Go to last post
  14. No chlorine present after winter
    It's been a rough New England winter. My above ground pool cover didn't hold up so well with the elements. It never came off completely but came...
    Started by Jacob99‎, 04-21-2014 06:06 PM
    04-21-2014 07:30 PM Go to last post
  15. Bought house with pool
    We bought a house with a cement in ground pool, oval shaped. I was worried about the previous owners closing of the pool, but so far so good. We have...
    Started by Bdeal‎, 04-16-2014 08:04 PM
    04-18-2014 09:43 AM Go to last post
  16. Pool is a swamp
    Greetings, new participant here. I thought I posted this question already, but I'm not sure I followed all the rules. So I'm going to throw it out...
    Started by docwagner‎, 04-07-2014 03:39 PM
    04-15-2014 12:38 PM Go to last post
  17. Question Trouble with opening pool
    I have a 16x32 in-ground...Last Sept I blew out lines thoroughly...Yesterday I removed Gizmo...There is no water flowing back to filter..I tried...
    Started by Earl J‎, 04-10-2014 09:24 AM
    04-10-2014 05:02 PM Go to last post
  18. Question Mystery drain plug
    Hello- New here! We have an inground Gunite pool with attached hot tub, that we used a company last year to open/close. They left all of the...
    Started by minnie75kids‎, 04-08-2014 07:00 AM
    04-09-2014 10:03 AM Go to last post
  19. Excited to be part of your community
    Hello all, I'm somewhat of a newbie. Bought a house w a pool a yr and half ago. Just started BBB method a few months ago and loving it. My pool...
    Started by Smforte‎, 04-04-2014 05:57 PM
    04-05-2014 12:23 AM Go to last post
  20. Shutdown spa?
    My spa is aboveground, 500 gallons and it is now march 2 and I was thinking would it be ok just to shut it off? It runs twice a day but I don't want...
    Started by dansdad‎, 03-03-2014 02:56 PM
    03-03-2014 07:12 PM Go to last post
  21. How long does the pump really need to run?
    Ok, just had a pool put in by shasta pools az. I have a pentair system 3 and a V.S. pump with a DE filter. Now the startup guy came out to turn on...
    Started by Dr.DieselFS‎, 11-04-2013 01:09 PM
    3 Pages
    1 2 3
    pump on-time, sticky
    01-03-2014 10:48 AM Go to last post
  22. Winter protection with Spa
    IG 18,500 + IG Spa 1 pump variable speed, Pool Cleaner Vac, 1 skimmer Intellichlor 3600 Buckeye, AZ I'm not sure how to winterize when I still...
    Started by Nomak2‎, 12-11-2013 10:33 AM
    12-13-2013 02:30 PM Go to last post
  23. Question What should we do for blown in pool cover?
    Hello! Back after a long hiatus where I just referred to all the notes I had printed out from your forum during the first few years of pool...
    Started by MaureenCab‎, 11-23-2013 12:07 PM
    11-25-2013 06:05 PM Go to last post
  24. Is Polyquat advisable during the FL winter?
    Living in the Clearwater, FL area, I have an easy job "winterizing" my pool. However, I do have a question. I have been adding three ounces of...
    Started by lanshark‎, 11-23-2013 05:15 PM
    11-24-2013 08:14 AM Go to last post
  25. Angry Really Scewed Up today !
    Well the end of pool season has come in central Texas once again. I purchased a new cover this year and had 3 friends show up this morning. As luck...
    Started by Heavyhook‎, 10-31-2013 06:13 PM
    11-10-2013 11:41 AM Go to last post
  26. Closing pool, algaecide added and PH level real high now
    Getting ready to close the pool, vacumed, then added algaecide (60% polyquat), about 3 hrs later tested the water, and the PH which had been 7.6 the...
    Started by tdurban‎, 10-19-2013 09:24 AM
    11-02-2013 01:06 PM Go to last post
  27. New to this forum
    I am new to this forum. I have a 30k gallon inground pool with salt chlorine generator system. Trying to close my self and looking for best advice...
    Started by Techy‎, 10-13-2013 07:53 AM
    10-18-2013 06:35 AM Go to last post
  28. Question Winterizing questions - fix algae now, or in spring?
    Hello forum! I am late in winterizing b/c I've been trying to get the green out after too long ignored. Now I'm wondering if I wait until spring or...
    Started by buhhdy‎, 10-15-2013 11:18 AM
    10-17-2013 03:21 PM Go to last post
  29. sandblasted pool vs. winter
    how to prepare a sandblasted concrete 33x14 in-ground swimming pool for freezing temp? I've decided to paint it next year. Do I cover it with tarp...
    Started by sierra7614‎, 10-17-2013 01:11 PM
    10-17-2013 03:16 PM Go to last post
  30. How many ppl BBB and winterize pool?
    I am fixing to close on a house with our first pool on the 24th. I will have a inground outside pool. I dont know the volume yet because it has a...
    Started by consoleman‎, 10-10-2013 01:56 PM
    10-12-2013 09:10 AM Go to last post
+ Post New Thread
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
