+ Post New Thread
Page 12 of 30 FirstFirst ... 2 10 11 12 13 14 22 ... LastLast
Threads 331 to 360 of 900
Forum: Pool Startup, Shutdown, & Winter Operation
Spring startup; new pool startup; fall shutdown & winterization.
  1. Sticky Thread Sticky: Closing an IG pool for the Winter
    Edit 12 Oct 06: Sorry I haven't gotten around to adding the pics I promised. The forum won't let me add any more attachments. Until this is resolved,...
    Started by Poconos‎, 09-18-2006 10:16 AM
    09-18-2006 10:16 AM Go to last post
  2. Sticky Thread Sticky: Closing an AG pool for the winter
    This is the procedure I use when preparing my AG pool for closing. I actually cover it pretty early in the fall before all the trees start...
    Started by Watermom‎, 09-04-2006 10:51 AM
    09-04-2006 03:03 PM Go to last post
  3. Exclamation Sticky Thread Sticky: FAQ: Common Spring Startup Errors
    This FAQ as been expanded, and moved to www.poolsolutions.com/gd/spring-swimming-pool-startup-problems.html Ben / PoolDoc
    Started by PoolDoc‎, 03-29-2006 09:59 AM
    03-29-2006 09:59 AM Go to last post
  1. Union (Quick-Connect) O-Ring Care
    This post is kinda pointed to CarlD but I'd love to hear anyone's opinion. When winterizing (disassembling) a plumbing system with Quick-Connects...
    Started by BigDave‎, 10-07-2011 09:09 AM
    10-12-2011 02:08 PM Go to last post
  2. 50 year old concrete pool.
    hello all, my wife and i recently inherited her grandparents house, with a 18x36 concrete pool, it may be 20x40, not sure, the pool was built in the...
    Started by jeffjr464‎, 10-05-2011 05:13 PM
    10-05-2011 06:37 PM Go to last post
  3. I've inherited a mosquito-breeding pool, and need to close it.
    My situation At my workplace, the guy who used to look after the pool and grounds recently died. So, as the nearest able body, his job has been...
    Started by DewiMorgan‎, 10-01-2011 04:32 PM
    2 Pages
    1 2
    10-05-2011 06:33 PM Go to last post
  4. Safety Cover "Mate" Cover? Are they worth it???
    I have had a green trampoline style safety cover on my pool for about 4 winters now. It allows water to pass through it but also allows sunlight to...
    Started by Pipecrew‎, 09-22-2011 03:02 PM
    10-05-2011 03:30 PM Go to last post
  5. Winterball?
    Is anyone using the Winterball or Winterpill? Is it beneficial or just a waste of $20. I'd search the forum for this info but it seems that I'm...
    Started by spattillo‎, 09-29-2011 03:36 PM
    09-29-2011 04:17 PM Go to last post
  6. Closing pool for first time
    Hi all, I have some questions re: closing my pool for the season. Stickies don't quite address the nuances of individual systems. Some of you...
    Started by elsie‎, 08-29-2011 11:21 AM
    09-26-2011 12:13 PM Go to last post
  7. closing of AG
    I have an 18x33 oval above ground, one year I used the bottles hanging from the eyelet method, but that ripped my eyelits out. Recently I've been...
    Started by Barry J‎, 09-14-2011 09:21 AM
    pix
    09-26-2011 12:10 PM Go to last post
  8. Blowing out main drawin IG pool
    Could someone please advise the steps to blowing out main drawin with air compressor. How do you close it off, will the water rise again? ...
    Started by FPICOL‎, 09-25-2011 12:01 PM
    09-25-2011 12:01 PM Go to last post
  9. Need help w/ blowing out lines IG pool
    IG Sylvan concrete pool Need to blow out returns and bottom drain. 1st what size air compresser do I need? I see there is an area for a grease...
    Started by FPICOL‎, 09-24-2011 01:50 PM
    09-24-2011 01:50 PM Go to last post
  10. Winter plugs
    Are winter plugs for an I/G pool standard size? I cannot find our from the spring and need to order some! Thanks for the information!
    Started by cammom‎, 09-22-2011 08:51 PM
    09-23-2011 12:17 PM Go to last post
  11. water level
    I have a 18 x 33 oval AG Where should I drain my water down to??? Just below the skimmer, or just below the return??? Is less water better than...
    Started by Barry J‎, 09-23-2011 07:39 AM
    09-23-2011 12:11 PM Go to last post
  12. Questions for Winter Closure of IG Pool
    I have a relatively new shotcrete IG pool which is going into it's second winter here in Reno NV. The first winter shut down I had the PB close it...
    Started by NevadaSteve‎, 09-21-2011 04:41 PM
    09-22-2011 03:26 PM Go to last post
  13. What type of winter cover should i buy?
    There are so many choices? which would you recommend? whats a simple winter closing kit solution? does the winterpill work? Thanks Jim
    Started by Jimcarter46‎, 09-19-2011 09:37 PM
    09-20-2011 09:08 PM Go to last post
  14. Need help with starting chlorine after drain/refill
    Hi all - so I am about to drain and refill my pool - water is scheduled to be delivered tomorrow afternoon. Have talked to our original installer at...
    Started by aciam‎, 06-23-2011 08:30 PM
    5 Pages
    1 2 3 ... 5
    high ccs, phmb conversion, sodium percarbonate, sticky
    09-18-2011 09:25 AM Go to last post
  15. Is antifreeze ok for pools?
    does antifreeze get filtered out by the filter in the spring?
    Started by burnszey‎, 09-16-2011 11:09 PM
    09-17-2011 08:27 AM Go to last post
  16. 20 gallons of acid???
    I am a new pool owner and have read many posts here. I now have a question. 22000 gal in ground, wet edge pebble sheen finish, Clean clear 420...
    Started by rcci01‎, 08-27-2011 12:07 AM
    09-15-2011 06:53 PM Go to last post
  17. Question Couple questions. 1st year of closing AG pool.
    I live in Michigan...the winters can be rough. So I want to be sure not to ruin the pool we've only had up for half a season now. Here are my couple...
    Started by HollyClo‎, 09-12-2011 07:15 PM
    09-14-2011 03:06 PM Go to last post
  18. to cover or uncover
    I'm new here...I bought a house with a pool and was able to enjoy it. It's getting close to the end of swimming season and was thinking about...
    Started by Txboynjgirl‎, 09-13-2011 01:12 PM
    09-14-2011 10:17 AM Go to last post
  19. Question Guidance Needed to Close Pool
    Last year I closed my pool myself for the first time. The pool store sold me a "kit" had me dump everything in and shut down. Opened to a slimy...
    Started by mortimay‎, 09-09-2011 01:48 PM
    09-09-2011 06:04 PM Go to last post
  20. Question A small pool, 12' x 3.25' .. 2150 gallons
    I have upgrade from the kiddy pool :) I am totally green hoping to be royal blue. What is the basic chemicals do I need to use, just got it filled...
    Started by Bearsbee‎, 07-04-2011 01:05 AM
    3 Pages
    1 2 3
    09-06-2011 11:00 PM Go to last post
  21. Red face Water Temperature for Pool Closing
    It is getting near the end of the season. Do I need to wait unitl the pool water temperature drops to a given temperature prior to closing or does...
    Started by Pamlicoknk‎, 09-04-2011 09:07 AM
    09-05-2011 06:43 PM Go to last post
  22. First time closer
    I've been reading closing threads. .......A couple of questions for closing the pool for the first time here in MI. It's a used 21' AG. The pool came...
    Started by Labpool‎, 08-22-2011 07:20 PM
    2 Pages
    1 2
    09-03-2011 12:21 AM Go to last post
  23. Not a Chemist! Need help with chemicals.
    17,000 gal AG pool. Here are my numbers from the pool store: FC 1.5ppm TC 1.5ppm pH 7.7 Alk (w/stabilizer correction) 236 CYA 46ppm ...
    Started by mortimay‎, 08-24-2011 12:23 PM
    08-24-2011 02:06 PM Go to last post
  24. Talking My New Pool is Up and Running!
    No problem here - just celebrating. Been a little less than a month but we're finally spinning the pump. I've no doubt that I'll be able to meet...
    Started by BigDave‎, 08-08-2011 12:30 AM
    08-21-2011 12:06 AM Go to last post
  25. Unhappy New Pool SWG & other questions
    New 41k+ plaster pool and I have a couple of questions and opinions to ask? 1We got a SWG and so far without shock we can't get it to produce...
    Started by maglib‎, 07-23-2011 01:30 AM
    2 Pages
    1 2
    black algae, sticky
    08-16-2011 07:17 AM Go to last post
  26. AG Pool not being used, would like to close for winter, Intex recommends taking down
    This is only the second year I've had a pool, at the end of last year we took it down and stored it like recommended by Intex. Now I'm wondering if...
    Started by kjh9835‎, 08-14-2011 05:41 PM
    08-14-2011 10:13 PM Go to last post
  27. Smile Need help shocking my swamp of a pool
    Hello, I have a pool which has been sitting closed with a canvas cover since 2009. I just pulled off the cover and took in the beautiful sight...
    Started by Wolf_man‎, 08-07-2011 11:40 PM
    08-08-2011 07:45 AM Go to last post
  28. New pool owner here
    Hi I would just like to say that this is a great site and I have already learned alot. So I have a new pool that I am getting filled tomorrow....
    Started by AndyD‎, 07-17-2011 06:11 PM
    2 Pages
    1 2
    08-05-2011 02:07 PM Go to last post
  29. Fiberglass pool
    Hello, I have a really dirty inground fiberglass pool, the color of the water is dark green almost black, I attempted to clean the deep end but it...
    Started by Aboabdo‎, 07-22-2011 11:43 AM
    08-01-2011 04:57 PM Go to last post
  30. Question first time pool owner needs help, please.
    I looked for a sticky on opening a pool for the first time but couldn't find exactly what I was looking for. My pool installation will be complete in...
    Started by sneal‎, 07-26-2011 03:24 PM
    07-28-2011 04:56 PM Go to last post
+ Post New Thread
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
