+ Post New Thread
Page 5 of 25 FirstFirst ... 3 4 5 6 7 15 ... LastLast
Threads 121 to 150 of 726
Forum: Pool Cleaning: Manual or Automatic
Polaris, Kreepy, Letro, Barracuda, or hand-to-hand combat with your pool!
  1. Cool Sticky Thread Sticky: Water Tech Blaster Pool Max Reviewed
    But seriously... I actually enjoy the process of vacuuming my pool (yes, I'm weird), and I think this comes partially from having a little bit of OCD...
    Started by MattW‎, 07-28-2012 03:21 AM
    3 Pages
    1 2 3
    battery vacuum, rechargeable vacuum, review, sticky, vacuum
    07-10-2016 04:45 PM Go to last post
  2. Sticky Thread Sticky: Pool Cleaner Reviews
    We seem to have had quite a few new questions about automatic pool cleaners. For those of you who have one, give us a review, please. -- What kind...
    Started by Watermom‎, 05-13-2014 04:03 PM
    2 Pages
    1 2
    06-13-2015 12:16 PM Go to last post
  1. I need a above ground Vac.
    I have a 33' above ground pool. Need a vac. I don't have a problem with leaves the biggest is dead algae from time to time. The vac. I have been...
    Started by Dirtboy6‎, 04-16-2013 09:26 PM
    04-17-2013 01:46 PM Go to last post
  2. hayward stops after 5 mins
    Trying this hayward pool vac ult ra and after 5 mins it stops. I notice on pool pump that when i started with acuum hose attached to skimmer and...
    Started by fhorta‎, 03-30-2013 02:37 PM
    03-30-2013 02:37 PM Go to last post
  3. polaris booster pump
    I have my polaris 380 set to run on a timer every day. I accidentally forgot to reconnect my Polaris to the pool after removing it for swimming one...
    Started by kimrob‎, 11-12-2012 05:31 PM
    12-09-2012 01:19 PM Go to last post
  4. The Pool Cleaner Made by Poolvergnuegen
    I'm considering buying a new pool vacuum. For the past 4 years I've been using a Hayward pool vac but I'm tired of rebuilding it and it still not...
    Started by mbeckner‎, 11-13-2012 02:03 PM
    11-13-2012 09:44 PM Go to last post
  5. trying to diagnose Polaris cleaner problem
    It had not been running all season. I have been cleaning the pool myself. The tip of the tale had worn off last fall and I was finally able to...
    Started by bri3180‎, 08-30-2012 11:51 AM
    11-09-2012 06:37 PM Go to last post
  6. Water does not appear to be filtered very well
    Last year we bought a used 24'x4' aboveground pool with a sand filter.(our 1st pool) I spent all summer reading this forum and we seemed to have...
    Started by leena‎, 05-25-2012 07:31 PM
    5 Pages
    1 2 3 ... 5
    11-04-2012 11:25 AM Go to last post
  7. Question Paramount MDX question
    Hi All, I have one of these debris removal systems in my pool (only about 12 months old). I've only been in the house for a few months so I don't...
    Started by vimfuego‎, 10-11-2012 07:26 PM
    10-11-2012 09:05 PM Go to last post
  8. Polaris 360 tieing itself in knots
    I recently replaced the entire hose assembly for my Polaris 360. The original hose had 6' lengths while the replacement has 10' lengths. I've tried...
    Started by Pahonex‎, 10-01-2012 02:24 AM
    10-04-2012 10:13 PM Go to last post
  9. Unhappy Bizarre dirt problem in pool
    Hi all, I have a fairly typical pool setup - hot tub attached to the main pool. I can adjust where my filters suck from, and where the water is...
    Started by MattW‎, 10-02-2012 05:32 PM
    10-03-2012 08:44 PM Go to last post
  10. PB4 booster leak
    It is leaking at the seal, is the motor shaft splined to the pump? Any disassembly info would be appreciated. I am hoping the pump will slide off...
    Started by fatstogie‎, 09-03-2012 02:38 PM
    09-04-2012 08:36 PM Go to last post
  11. Polaris 65 Turtle
    We are going to have to buy a new pool vac. Have been looking at the Polaris 65 Turtle. Anyone have any pros/cons on this one? Not sure which vac to...
    Started by tnalaskan‎, 09-03-2012 07:26 PM
    09-04-2012 06:49 AM Go to last post
  12. Hayward Ultra Vac Not Moving
    My Ultra Vac recently stopped moving - my suction is good and all of the consumables have been replaced. When it's on the bottom of the pool, the...
    Started by matthewnadeau‎, 08-12-2011 12:28 PM
    09-02-2012 04:15 PM Go to last post
  13. Aquabot Vac stops intermittently
    I was reading a post from July 2011 on this site where the poster said their Aquabot would start and stop intermittently. Our Aquabot Turbo is doing...
    Started by JCASR‎, 08-26-2012 05:48 PM
    08-30-2012 05:05 PM Go to last post
  14. trouble with my automatic pool sweep
    I recently baught a used pool with all the trinkets that came with it including an automatic pool sweep... My pool sweep is a DIRT DEMON not a...
    Started by jesse‎, 08-27-2012 09:34 AM
    08-29-2012 07:53 AM Go to last post
  15. Ok, so there's all this DE sediment in my pool, put in by mistake....
    by the pool guy before I knew any better ( turns out I have cartridge filters, not DE filters ). Pool guy was not a regular but only hired to clean...
    Started by St8kout‎, 08-23-2012 07:43 PM
    08-24-2012 10:26 PM Go to last post
  16. Question Hooking up a Baracuda G4 questions
    I recently purchased a Baracuda G4 and plugged it directly into the skimmer. Since I am now bypassing the skimmer basket, I now clean out the pump...
    Started by Bjorn‎, 08-20-2012 06:49 PM
    08-20-2012 06:49 PM Go to last post
  17. First post!
    Here to do some research about automatic pool cleaners...what a PITA! I've already dumped several hundred into repairing the pool this year only to...
    Started by jeld44‎, 08-17-2012 08:07 AM
    08-17-2012 08:07 AM Go to last post
  18. ABG Ranger, Aqua Critter, or something else?
    We've had our Zodiak Ranger for about 8 years and the ring broke years ago (still in place but not solid in the one place) and now the internal...
    Started by abadubs‎, 08-14-2012 10:36 AM
    08-14-2012 10:36 AM Go to last post
  19. Portable home made vacuum HELP! PICS INCLUDED
    Hello guys I'm new here! I joined because I could really use some help regarding vacuuming my... Not so ordinary pool. To start my pool doesn't...
    Started by Antman2x2‎, 08-02-2012 07:17 PM
    08-12-2012 06:23 PM Go to last post
  20. Vacuum pressure switch for Barracuda?
    Sorry to post such a complicated question as my first one, but it's what I need help with. We have a large inground pool with solar heating and a...
    Started by henryb‎, 08-11-2012 08:25 PM
    08-11-2012 08:25 PM Go to last post
  21. Unhappy robo kleen sweeper
    I have a Robo Kleen sweeper for my above ground pool. When I place it in the pool and turn it on, it will go forward about two feet and then bakward...
    Started by gary_grdnr‎, 08-05-2012 12:30 PM
    08-06-2012 10:52 PM Go to last post
  22. aqua bot pool rover jr
    Hi all, I have the above cleaner for my AG vinyl pool. On the cord that plugs into the transformer is a BIG note saying 'DO NOT REMOVE THE CLEANER...
    Started by mike in arkansas‎, 08-05-2012 05:14 PM
    08-06-2012 10:00 AM Go to last post
  23. Post Polaris 360 Feed Hose Repair Info
    I just wanted to share some information I wish I knew before I attempted to repair the feed hose on my Polaris 360 pressure side pool cleaner. My...
    Started by clueless at times‎, 08-03-2012 05:01 PM
    08-04-2012 09:43 AM Go to last post
  24. Intex Pool: New filter will not pick up fine debis...
    Intex pool: New filter will not pick up fine debris and blows it back into the pool. What to do besides pumping water outside of the pool and...
    Started by larydare‎, 07-29-2012 02:33 PM
    08-04-2012 08:28 AM Go to last post
  25. I've Registered.......
    Okay....I've registered....now what? I'm wanting to read some articles on robotic pool cleaners in order to help me make my purchase. Any...
    Started by Shadow3‎, 07-30-2012 06:15 PM
    08-03-2012 08:18 PM Go to last post
  26. Question Skimmer Sock or Panty Hose in Pump Basket?
    My DE filter grids need to be replaced; however, I have decided to wait until next season to replace them. I don't want to install new grids then...
    Started by Shifty‎, 07-31-2012 09:36 PM
    2 Pages
    1 2
    links to fix
    08-02-2012 11:12 AM Go to last post
  27. Rebuild 1990 Arneson Cleaner?
    When we bought our house in 1999 we inherited the pool and an Arneson pool cleaner. When the Arneson performance started failing I replaced it with...
    Started by Ken_J‎, 07-30-2012 04:49 PM
    07-30-2012 04:49 PM Go to last post
  28. Issue with Tracker cleaner?
    I have a 4-wheel Tracker that I've been using for a few years now. When it gets to the base of the wall, the wheels keep turning until it...
    Started by Ken_J‎, 07-30-2012 12:51 PM
    07-30-2012 12:51 PM Go to last post
  29. Help. Large glass table flew into inground 36'by18' pool
    Big storm today took our seat 8 glass table with umbrella into pool and millions of little shards of glass in shallow end, heading toward deep end....
    Started by Tennislou‎, 07-28-2012 01:18 AM
    07-29-2012 09:58 PM Go to last post
  30. Pop-Up Head Cleaning in a SW Florida Lanai??
    I posted this in the getting started area (forced too)...but thought might get more feedback here. Pop-Up Head Cleaning in a SW Florida Lanai?? ...
    Started by ArmyChief‎, 07-28-2012 02:33 PM
    07-29-2012 12:14 AM Go to last post
+ Post New Thread
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
