+ Post New Thread
Page 4 of 49 FirstFirst ... 2 3 4 5 6 14 ... LastLast
Threads 91 to 120 of 1468
Forum: Above-Ground Pool Construction & Repair
Got an AG pool question? I'm no expert, but someone else here might be!
  1. Sticky Thread Sticky: FAQs & Guides: Above-ground pools
    ___________________________________________ FAQs & Guides: Above-ground pools ___________________________________________ I'm updating the...
    Started by PoolDoc‎, 06-25-2018 02:21 PM
    06-25-2018 02:21 PM Go to last post
  1. Above Ground Radiant 27' Metric Build
    Hello all. Today I will be starting my replacement build on my new pool. Old pool was rusting on the top panels and slightly on the walls which was...
    Started by KPROMERO‎, 05-15-2014 02:05 AM
    2 Pages
    1 2
    06-23-2014 07:58 PM Go to last post
  2. Walls caving in while filling
    I have a 24' Westminister II pool. I am filling it for the first time. The instructions said to start filling after the wall was up and the...
    Started by Drbrichy‎, 06-22-2014 10:56 AM
    06-23-2014 01:29 PM Go to last post
  3. AG pool liner keeps falling off
    I moved to a house with an oval above ground pool that was closed for 2 years. The water was black and tried to clean it for 3 weeks but not luck so...
    Started by Lindsay‎, 06-21-2014 10:21 PM
    06-23-2014 12:24 AM Go to last post
  4. Exclamation Repairing Leak Underwater
    We just filled our inflatable 15' Summer Escape for its second year of Unimed duty, and I found a 1/16"x1/4" hole in the bottom of the liner, about...
    Started by MunkeyTX‎, 06-22-2014 12:16 AM
    06-22-2014 07:23 PM Go to last post
  5. Anyone have experience using lime?
    Newbie here. I am in the process of trying to repace a 18x33 above ground. Problem is with all the rain we have gotten I can't seem to dry out the...
    Started by marsh‎, 06-20-2014 08:24 PM
    06-22-2014 04:09 PM Go to last post
  6. Newbie - what type above ground pool for our family?
    After bugging the hubby for years about springing for an inground (I grew up with one) I can see it'll never happen! His compromise is to get a bid...
    Started by Damasco‎, 06-19-2014 04:05 PM
    06-22-2014 12:23 PM Go to last post
  7. New AG Pool Build - Still Shopping
    We are wanting to put in a AG pool partially buried to meet up with our existing deck. I think I like the Radiant Metric. Does anybody have...
    Started by ChickenFarmerJohn‎, 06-18-2014 09:52 PM
    06-21-2014 04:27 PM Go to last post
  8. Hello! new Kayak pool
    We just had our new pool install and we are all ready for swimming. Right now we are trying to get all the chemical ranges right. Here some...
    Started by auttienkassiemom‎, 06-18-2014 01:10 PM
    06-20-2014 04:57 PM Go to last post
  9. Liner Issue - Extra floppy on the toppy
    Hey folks, First post here. Just got my water level up over the skimmer, turned on and loaded the DE and got my levels up to something resembling...
    Started by Subliminal‎, 06-17-2014 12:46 PM
    2 Pages
    1 2
    06-20-2014 11:43 AM Go to last post
  10. How can I replace an Esther Williams pool liner
    Hello. I'm in the unfortunate position of having to replace an Esther Williams beaded liner. As many of you may know, they're much more expensive...
    Started by yj2cute‎, 06-11-2014 02:45 PM
    06-19-2014 09:56 AM Go to last post
  11. waterco aquamite above ground pool pump
    Recently i had to change the actuator plate. The pump ran great before i had replaced the plate and siliconed the rings. Now it hums for a few...
    Started by Saber6G‎, 06-17-2014 12:44 PM
    06-17-2014 07:47 PM Go to last post
  12. Unhappy Pool walls buckling while filling pool
    New pool started filling pool about 6" water noticed walls on one side of pool buckling. Liner looked good when we started filling. Is this normal?
    Started by bdelaurier‎, 06-15-2014 09:17 PM
    06-16-2014 08:56 PM Go to last post
  13. Severe rust at bottom of upright posts
    I have a 10 year old 24; above ground pool that was made by rec warehouse, so given that it has lasted this long is amazing in itself lol. The pool...
    Started by michael3‎, 06-16-2014 09:01 AM
    06-16-2014 10:22 AM Go to last post
  14. Pool Liner issues
    I am new to this and am just trying to get a little advice. We just had our pool liner replaced (June 7/8) and from the start I have not been...
    Started by amgaut‎, 06-10-2014 04:07 PM
    06-14-2014 11:18 PM Go to last post
  15. Leak in main drain located in vermiculite outside pool wall
    I've verified a leak in the main drain line of my inground pool. Dug down to the line only to discover that there's still about 6" of line outside...
    Started by Cgheet‎, 06-13-2014 04:09 PM
    06-14-2014 10:34 PM Go to last post
  16. Smile How do I obtain variable depth in an above ground pool... Help!
    Hi guys, I dont really know if this is even possible, but this is my situation.. I just got a 14' x 42" above ground round pool, with metal...
    Started by RIpoolNewbie‎, 06-12-2014 02:47 PM
    06-14-2014 05:29 PM Go to last post
  17. Re-setting above ground pool on wet clay?
    Not sure if anyone has advice - we are in the process of re-setting our above ground pool. Short story- the installers put the pavers and bottom...
    Started by Mningrounddream‎, 06-10-2014 04:53 PM
    06-14-2014 01:57 PM Go to last post
  18. Rust under skimmer
    So when we took off the cover, we noticed that the wall around the skimmer was bent in slightly, the wall is out of the rail that holds it at the...
    Started by teach16711‎, 06-11-2014 05:29 AM
    06-13-2014 11:48 PM Go to last post
  19. Under liner support straps
    I have a 16' x 32' Kayak rectangle pool, and this winter one of the support straps running under the liner broke. I called Kayak but they want more...
    Started by hoover460‎, 06-10-2014 01:43 PM
    06-13-2014 12:27 AM Go to last post
  20. above ground pool on a steep sloped yard.
    I am sure this question has been asked several times, but search doesn't seem to be working for me. So, here goes. I have a sloped back yard and...
    Started by amyatkin‎, 06-09-2014 10:57 PM
    06-12-2014 09:58 PM Go to last post
  21. Installing a fafco solar heater
    I was wondering if anyone has any pictures of their solar panel and how it's connected. We have to put ours about 20ft away from the pool to get good...
    Started by dtjoseph95‎, 06-10-2014 11:46 PM
    06-11-2014 12:42 PM Go to last post
  22. In ground pool top rail parts
    I have an in ground pool, and I am looking for the covers that snap into place between the aluminum top rail sections to cover the gaps. Anyone have...
    Started by MUTZIE77‎, 06-10-2014 12:55 PM
    06-10-2014 11:12 PM Go to last post
  23. Chlorine useage in pressure washer near pool
    Can I use Chlorine Bleach in my pressure washer to clean my wood deck which is attached to the pool without ruining the vinyl liner?
    Started by Tony B‎, 06-09-2014 07:42 PM
    06-10-2014 05:01 PM Go to last post
  24. Newbie lowering water level on above ground pool
    We are in our new house that has a 24' circular pool 52" high. I know that the water level is required to be about 1/2 to 3/4 of the way up the...
    Started by georgenelia‎, 06-07-2014 04:57 PM
    06-10-2014 01:08 AM Go to last post
  25. AG pool liner installation problems
    I'm new here, from SE Utah near Lake Powell, renting an older house which has a 24' above ground pool, surrounded by wood decking that we just...
    Started by PPD5513‎, 06-08-2014 05:03 AM
    06-10-2014 12:37 AM Go to last post
  26. 15x30 above ground
    I need a new linver , overlap design 52 in walls and was looking for recomendations about who to get one from, I am about to pull my hair out...
    Started by donintc‎, 06-06-2014 08:24 AM
    06-08-2014 02:34 PM Go to last post
  27. Above ground pool wall problem
    I have an above ground pool with a deck around it. I drained the pool a couple of weeks ago to repair a leak and clean it. Upon filling it, the top...
    Started by Mdlbarnard‎, 06-05-2014 04:54 PM
    06-07-2014 10:49 PM Go to last post
  28. Hose connectors from solar panel to pool leaking
    Okay, where my husband hooked up the two hoses from the solar panel to the hoses that are connected to our pool are leaking. Any help as to what we...
    Started by mommak‎, 06-07-2014 11:53 AM
    06-07-2014 10:28 PM Go to last post
  29. new user with AG liner problems
    Hi I was looking to see if anyone can tell me the best way to empty my pool once down to an inch and sump pump stops working? I have a semi...
    Started by Crazynutjob‎, 06-03-2014 08:00 PM
    06-06-2014 10:30 PM Go to last post
  30. Unhappy Beaded liner problems
    Is it imperative that you use a shop vac to set your liner? I have a Johnny weissmuller 24$ round in which we just replaced the liner. It was...
    Started by bridrob‎, 06-03-2014 03:26 AM
    06-04-2014 10:53 AM Go to last post
+ Post New Thread
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
