+ Post New Thread
Page 52 of 121 FirstFirst ... 2 42 50 51 52 53 54 62 102 ... LastLast
Threads 1531 to 1560 of 3628
Forum: Pool Equipment & Operations
Pumps, pipes, filters, lights; covers, valves, heaters, coolers; filling and draining . . .
  1. Sticky Thread Sticky: How Much Does Pump Efficiency Matter?
    ___________________________________ How Much Does Pump Efficiency Matter? ___________________________________ TL;DR: The difference in...
    Started by PoolDoc‎, 06-23-2018 09:02 PM
    06-23-2018 09:02 PM Go to last post
  2. Sticky Thread Sticky: FAQs & Guides: Pool Equipment & Operations
    ____________________________________ FAQs & Guides: Pool Equipment & Operations ---- June 2018 ---- ____________________________________ ...
    Started by PoolDoc‎, 06-19-2018 05:06 PM
    06-19-2018 05:06 PM Go to last post
  3. Sticky Thread Sticky: Need advice regarding cartridge filter...
    I've spent the last three years (yes, that's THREE) rebuilding my existing pool that was originally built in the mid 50's. Lots of problems, lots...
    Started by otisdog‎, 05-23-2014 03:45 PM
    05-29-2014 10:38 AM Go to last post
  1. whisperflo pump running hot
    my pump takes several minutes to pull water and when it finally does it runs very hot, much hotter than it has previously. it has not stopped on me...
    Started by klewando‎, 07-13-2011 02:40 AM
    07-14-2011 10:29 AM Go to last post
  2. Foam in Weir
    I came looking for info....wondering if I can replace the foam in the weir rather than purchasing a whole new door/flap. It is flaking and looks...
    Started by jpris‎, 07-12-2011 09:15 PM
    07-14-2011 09:24 AM Go to last post
  3. Red face Timer for Intex metal frame pool?
    Hi There, We have a 12 x 30" round Intex pool. Does anyone know if these types of pools are able to be used with a timer? I have purchased a...
    Started by drako4‎, 07-10-2011 12:31 PM
    07-13-2011 06:12 PM Go to last post
  4. Hayward EC50AC pumping green back in pool???
    When filter gets tuned on, it shoots what looks like green algea back into the pool for about 10-15 sec, then return water clears up. I've been...
    Started by poolguy123‎, 07-09-2011 10:04 AM
    07-13-2011 11:29 AM Go to last post
  5. Filter Run-time Schedule
    Hey everyone- We just set up a used 18' round pool. (approx 7000 gal) I've been getting great info on getting the chemicals figured out. Everyone...
    Started by chinewalker‎, 07-11-2011 01:07 PM
    07-12-2011 10:29 AM Go to last post
  6. Question about in-wall connection for Polaris
    I have a Polaris 380 pool cleaner and need to replace the in wall connection that the polaris line connects to. I am ordering the tool to remove the...
    Started by stepbill‎, 06-23-2011 02:26 PM
    07-11-2011 09:22 PM Go to last post
  7. Salt on bottom of pool?
    Hello everyone. I have an above ground resin 15x26 oval pool with a compupools saltwater system. I have a Hayward sand filter and hayward pump. I...
    Started by Mr.Mooks‎, 07-08-2011 01:34 PM
    07-11-2011 07:48 AM Go to last post
  8. AG pump/filter question - have a lot of suction at the skimmer and return
    First post so I hope this is routed to the correct place. I have a 24' round pool. Last year while I was travelling for work my wife and son decided...
    Started by bbink‎, 05-16-2011 01:30 PM
    2 Pages
    1 2
    07-10-2011 04:17 PM Go to last post
  9. Cool pump running 24/7 or what?
    I have very clear water, but I also run pump 24/7 should I do that, or should I for pump sake put it on a timer as so it don't run all time or should...
    Started by airraid1999‎, 07-01-2011 11:37 AM
    2 Pages
    1 2
    07-09-2011 05:39 PM Go to last post
  10. New Pool Owner - general 'what now' questions
    Hey all, We have an in-ground - in-door pool with a Pentair Tagelus Sand Filter. The pool is kinda large and we love having in our new...
    Started by MajorMench‎, 07-09-2011 03:26 PM
    07-09-2011 04:21 PM Go to last post
  11. All kinds of ?'s
    We're new to the pool scene and have had a bunch of issues this summer, most of which have been resolved but they keep coming so any help would be...
    Started by keith2409‎, 07-09-2011 12:47 AM
    07-09-2011 01:13 PM Go to last post
  12. Sand filter question
    I just opened my pool for the first time in several years. It has been covered this whole time but there are a lot of leaves and gunk on the bottom....
    Started by waldreps‎, 07-05-2011 09:49 PM
    07-09-2011 01:09 PM Go to last post
  13. glass filter media
    Hi all: anyone heard of recycled glass filter media? The installer who replaced my liner carries it as one of his accessory lines. The...
    Started by drband‎, 07-09-2011 08:09 AM
    filter media, filtration, sand, zeolite
    07-09-2011 09:50 AM Go to last post
  14. Very high pressure HELP!!
    hey everyone im new to the forum and to home ownership, i just moved in and i noticed that my pressure gauge is reading 30-35psi so i followed...
    Started by ALGESIDE‎, 06-29-2011 10:16 PM
    07-09-2011 09:37 AM Go to last post
  15. Above ground filter options
    This is my second year with our 16 x 4 Intex pool. I've been using pool chemicals from Walmart and only have the strips and drop kit right now. Each...
    Started by OdinIII‎, 07-06-2011 12:48 PM
    07-09-2011 04:02 AM Go to last post
  16. Public Pool Flow & Turnover Problem
    I'm getting about 80 gpm. I'll never get to the 244 gpm required to turn my pool in 6 hours. I would, however, like to improve upon the 80 gpm. ...
    Started by watervale‎, 06-28-2011 09:14 AM
    07-08-2011 10:33 AM Go to last post
  17. Sand Filter Question
    Does anyone know how many pounds of sand an old Pac-Fab PF-50 sand filter holds? I'm thinking it is 200lbs but I can't find it anywhere on the...
    Started by waldreps‎, 07-06-2011 10:31 PM
    07-07-2011 07:38 PM Go to last post
  18. Wood Stove heater
    Question 1: What additional chemical issues might I have to worry about due to the fact that I heat my pool to 98-101 in the winter with a wood stove...
    Started by tdkorson‎, 07-06-2011 07:29 PM
    07-07-2011 05:33 PM Go to last post
  19. Converting Sta-Rite system 3 cartridge to DE
    First post, I was directed to the forum by a google search but could not continue my research due to not having permission, so here it goes! I've...
    Started by kidjetta‎, 07-05-2011 05:00 PM
    07-07-2011 03:58 PM Go to last post
  20. Low Water Cut off
    hello, i have an in ground pool, salt /auto pilot/haywood pump&filter. has anyone used a low water cut off valve to shut down the pump if water...
    Started by joe1028‎, 07-07-2011 12:50 PM
    07-07-2011 12:50 PM Go to last post
  21. Leaking Hayward S 240 filter
    Hi...a few months back I noticed a drip from the bulkhead fittings on the filter..it was coming from between the filter and the fitting..mostly the...
    Started by sheltsound‎, 07-07-2011 01:00 AM
    07-07-2011 01:00 AM Go to last post
  22. Question Contract installation of new pump and filter or DIY?
    I can find the pump and filter I want to purchase on line much cheaper than the pool company wants to sell it to me. They will install but "scare"...
    Started by jodyjim‎, 07-05-2011 11:58 PM
    07-06-2011 03:28 PM Go to last post
  23. Purex Triton 4000 DE Filter - 60sq ft
    I want to remove the valve under the filter grid manifold. I have taken off the handle assembly that moves the valve from filter to backwash. The...
    Started by spbb05‎, 07-03-2011 02:54 PM
    07-04-2011 06:05 PM Go to last post
  24. Silt on pool bottom from filter
    Hi everyone :) Another year, another (ongoing) problem. Our sand filter is dumping silt in the bottom of the pool. The water is crystal clear...
    Started by maryberrye‎, 07-03-2011 08:44 PM
    07-04-2011 04:25 PM Go to last post
  25. sta rite intellichoice reviews
    Anyone have experience, god or bad withe these pumps? Thanks, Kevin
    Started by lammi66‎, 07-01-2011 03:58 PM
    07-03-2011 10:34 PM Go to last post
  26. Proline sand filter and Proline Pump
    Hi, I want to setup a dismantled proline sand filter for my above ground pool. The sand filter and pump are from proline and the connecting pipes...
    Started by sumanksingh‎, 07-02-2011 10:06 PM
    07-03-2011 10:33 AM Go to last post
  27. changing filter sand
    Yesterday I changed the sand in my filter, everything seemed to go back just the way I removed it. My problem now is I have air in my lines...
    Started by jrtvols‎, 06-26-2007 05:29 PM
    07-02-2011 07:44 PM Go to last post
  28. Taglus filter help
    we have had our pool and filter for quite a while. So long that the words for the functions have worn off the top. Are all filters arranged the same...
    Started by chargeit2him‎, 07-02-2011 11:14 AM
    07-02-2011 05:06 PM Go to last post
  29. PAC-FAB fiberglass Filter
    Does anyone have any tricks on unscrewing the Vari-Flo valve from this tank.
    Started by scott e‎, 07-01-2011 09:01 PM
    07-01-2011 09:28 PM Go to last post
  30. Salt Generator + Automation?
    I am considering adding an SWG. I have recently added a new pump (Pentair intelliflo VS-3050) and am also getting a new heater (Pentair/Sta-Rite...
    Started by qwerty3656‎, 06-29-2011 04:00 PM
    07-01-2011 05:46 PM Go to last post
+ Post New Thread
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
