+ Post New Thread
Page 4 of 121 FirstFirst ... 2 3 4 5 6 14 54 104 ... LastLast
Threads 91 to 120 of 3628
Forum: Pool Equipment & Operations
Pumps, pipes, filters, lights; covers, valves, heaters, coolers; filling and draining . . .
  1. Sticky Thread Sticky: How Much Does Pump Efficiency Matter?
    ___________________________________ How Much Does Pump Efficiency Matter? ___________________________________ TL;DR: The difference in...
    Started by PoolDoc‎, 06-23-2018 09:02 PM
    06-23-2018 09:02 PM Go to last post
  2. Sticky Thread Sticky: FAQs & Guides: Pool Equipment & Operations
    ____________________________________ FAQs & Guides: Pool Equipment & Operations ---- June 2018 ---- ____________________________________ ...
    Started by PoolDoc‎, 06-19-2018 05:06 PM
    06-19-2018 05:06 PM Go to last post
  3. Sticky Thread Sticky: Need advice regarding cartridge filter...
    I've spent the last three years (yes, that's THREE) rebuilding my existing pool that was originally built in the mid 50's. Lots of problems, lots...
    Started by otisdog‎, 05-23-2014 03:45 PM
    05-29-2014 10:38 AM Go to last post
  1. Wood burning heated pool idea
    Anyone sell a product or have any ideas on how to do this? Are they not done in rural areas as often because its not worth the effort? I...
    Started by Saltysteve‎, 06-08-2018 11:31 AM
    06-08-2018 11:41 AM Go to last post
  2. Couple more sand filter questions.
    Picked up a used filter/pump setup. The pump appears to be the same (1hp) power as my old pump. The sand/filter container is significantly smaller....
    Started by bssage‎, 05-31-2018 02:04 PM
    06-01-2018 07:39 AM Go to last post
  3. What causes damage to copper heat exchanger in pool heaters?
    Has anyone had any problems using a gas heater with a copper heat exchanger. I'm keeping the chemistry right (pH usually 7.4-7.8) and do not want to...
    Started by Steve_in_NC‎, 05-28-2018 11:22 PM
    05-29-2018 06:17 AM Go to last post
  4. Solar Cover recomendations IG 18x36
    need to purchase replacement solar cover for our 18 X 36 IG. looking for recommendations for reputable web sites and thoughts on best one to buy....
    Started by kroberts04090‎, 05-27-2018 06:37 PM
    05-28-2018 12:26 PM Go to last post
  5. Selecting the best sand filter media types?
    Getting ready to change my sand(silca) filter media. Any opinions on the different types of available materials I.E. Glass, Poly Balls etc . . . ? ...
    Started by bssage‎, 05-27-2018 09:32 AM
    05-27-2018 04:44 PM Go to last post
  6. Replacing a 400k BTUH Minimax heater -- what's best?
    Hi, I am in Connecticut and I have/had a Purex Triton Minimax Plus 400 heater (Propane) for 15 years, it was a beast. My property got hit by a...
    Started by mpm32‎, 05-25-2018 10:10 AM
    05-25-2018 06:11 PM Go to last post
  7. Wood burner heating for swimming pool in England
    Hello, I live in Surrey England and have a pool approx 20x10 ft, 5 ft deep (indoors). Considering a combination of Air source heat pump for summer...
    Started by Anonymous European‎, 08-10-2013 11:58 AM
    05-25-2018 08:06 AM Go to last post
  8. Hayward h150fdn heat exchanger copper (cupro-nickel) tube pipe busted
    Opening my pool and noticed my pool heater leaking water from inside. I took panels off and learned that two of the copper tubes that come out of the...
    Started by dlupica‎, 05-22-2018 08:16 PM
    05-22-2018 09:07 PM Go to last post
  9. Pool pump outside. In Canada.
    I have a Hayward Super Pump 1HP that is pretty much gone. It's running loud and hot so I want to replace it but I don't have $700 to replace it with...
    Started by jthornton‎, 05-19-2018 08:17 PM
    05-20-2018 02:11 PM Go to last post
  10. Installing a cartridge filter
    I'm switching from a sand filter to a cartridge filter. Do I need the pressure hose between the pump and filter or is a regular pool hose sufficient?...
    Started by Feathers50‎, 05-17-2018 10:59 AM
    05-17-2018 11:07 AM Go to last post
  11. Unhappy Hoping BBB Method can help!
    We have a 36 foot above ground pool, 27,000 gal. We have an eco Kleer waterway pump and sand filter. I’ve noticed a lot of people have success...
    Started by Angela2928‎, 05-15-2018 07:06 PM
    05-15-2018 10:16 PM Go to last post
  12. Using DE in a sand filter to (a) test function or (b) boost filtration
    Using DE in a sand filter to (a) test function or (b) boost filtration DE powder is a white fine granular material, made of algae fossils...
    Started by PoolDoc‎, 05-15-2018 10:10 PM
    #update-sticky
    05-15-2018 10:10 PM Go to last post
  13. Question solar blanket blown by wind
    My solar blanket on my IG 16x32 pool is blowing to one side . This is happening in less than 14mph winds. At one point last season the reel was...
    Started by essikr‎, 05-10-2018 07:24 PM
    05-11-2018 10:32 AM Go to last post
  14. Pool heater with pump control
    Good Day All- I hope you are well. I may have asked this last year but cannot find it. I have an old(2007) Jandy Jxi heater that has the...
    Started by aea6574‎, 05-09-2018 10:44 AM
    05-09-2018 01:05 PM Go to last post
  15. Replacement filter system recommendation
    I've got a System3 cartridge filter that has sprung a leak in the lower casing. I've tried and a couple of repairs but it's started leaking again. ...
    Started by HappyWino‎, 04-30-2018 02:26 PM
    05-04-2018 12:15 PM Go to last post
  16. Cannot start pump and hayward multiport SP0714g11m to prime...
    I had everything new installed. Super pump, Hayward Multiport SP0714g11m, SWG, etcc. I attached everything, the pump was in recirculate mode. I...
    Started by phillipjko‎, 05-02-2018 11:11 PM
    05-04-2018 12:04 PM Go to last post
  17. Operating & Cleaning a DE filter
    The manual for my Hayward EC65A De filter says if the pressure rises more than 10 lbs you should clean the filter. How do I do this?
    Started by packerfan‎, 08-16-2009 02:05 PM
    2 Pages
    1 2
    de filter, sticky
    05-03-2018 07:54 PM Go to last post
  18. Cool My new 'old' pool with Hayward Superpump and S200 filter
    I am new to pool ownership and would welcome any tips or suggestions. I recently purchased a house with an inground pool of "unknown origin". Don't...
    Started by Zacherley‎, 04-22-2018 09:33 AM
    05-03-2018 08:30 AM Go to last post
  19. old pool flat return covers
    I have an old pool probably built in in the late 70's with the house. I am having a hard time finding the flat covers that sit on the bottom of the...
    Started by Swieser‎, 04-23-2018 02:03 PM
    05-03-2018 08:25 AM Go to last post
  20. Polaris stuck on front wheel
    Hey guys! First time poster here. I've read a bunch of posts but can't seem to find my exact question (or answer!). I have a 30,000 g pool. I have...
    Started by navy2x‎, 04-24-2018 10:41 AM
    05-03-2018 08:12 AM Go to last post
  21. New to me old pool
    I just bought a 30 years old house with a pool. It works. The pump looks old and the sun has destroyed the tag the would tell me the hp . It is...
    Started by Manateepool‎, 04-12-2018 06:36 PM
    04-12-2018 08:20 PM Go to last post
  22. How to glue in 12" of pipe and fittings into 9"
    Can someone point me to a tutorial on how to glue in a, well in this case a Jandy energy filter, into the middle of piping. Between the...
    Started by rocks911‎, 03-30-2018 05:13 PM
    03-30-2018 05:13 PM Go to last post
  23. Wink Hand me down pump comparison/question..
    Hi, Upon trying to startup my pool this year, I found my pump was seized up. It was leaking a bit at the shaft seal for a bit so I guess it...
    Started by mastamoon‎, 06-26-2017 10:50 AM
    06-28-2017 09:51 AM Go to last post
  24. No suction at skimmer (kinda long)
    Hello. First let me say I'm NO pool guy by any stretch, up until 4 years ago when we purchased this house I had never had any experience with...
    Started by JenniferC‎, 06-18-2017 01:08 PM
    2 Pages
    1 2
    06-27-2017 10:48 PM Go to last post
  25. Spa Light Replacement
    I have a Hayward Spa Light (Housing = SP-601, Fixture = SP-529HSL) that requires a bulb change every 1 or 2 years and I wanted to check if there was...
    Started by matthewnadeau‎, 03-28-2016 05:39 PM
    06-23-2017 06:58 PM Go to last post
  26. Evaporation
    I though I had a leak so I did the bucket test and it's all evaporation. We are in the middle of a heat wave here in Arizona (119* yesterday) with...
    Started by Phillbo‎, 06-21-2017 12:07 PM
    06-22-2017 02:59 PM Go to last post
  27. Jandy VS PlusHP
    I am looking to replace my Jandy PHPM1.5 pump ( rebuilt and is acting up again ) with a variable speed pump to save on electricity costs. Jandy VS...
    Started by CJDahl‎, 06-04-2017 03:16 PM
    06-04-2017 03:16 PM Go to last post
  28. types of thermistors in water temperature sensors, and possible failure modes
    Hi, one of my solar controllers started acting up and I am trying to isolate the problem. I measured the resistance of the sensor in the return...
    Started by semenzato‎, 03-04-2017 11:01 PM
    06-03-2017 07:33 PM Go to last post
  29. what gauge of liner and how to stop ants
    So ive been complaining about a leak for the last 3 years or more. I finally discovered it was tiny holes in the bottom egde of pool. Where the...
    Started by leena‎, 04-13-2017 04:32 PM
    2 Pages
    1 2
    05-28-2017 08:09 PM Go to last post
  30. Hayward ECommand 4 Clock Issues
    I have a Hayward ECommand 4 control system on my in-ground pool. Recently the clock has not kept proper time. Does anyone know if there is a battery...
    Started by stuckpipe‎, 05-18-2017 04:15 PM
    05-18-2017 04:15 PM Go to last post
+ Post New Thread
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
