+ Post New Thread
Page 101 of 121 FirstFirst ... 51 91 99 100 101 102 103 111 ... LastLast
Threads 3001 to 3030 of 3628
Forum: Pool Equipment & Operations
Pumps, pipes, filters, lights; covers, valves, heaters, coolers; filling and draining . . .
  1. Sticky Thread Sticky: How Much Does Pump Efficiency Matter?
    ___________________________________ How Much Does Pump Efficiency Matter? ___________________________________ TL;DR: The difference in...
    Started by PoolDoc‎, 06-23-2018 09:02 PM
    06-23-2018 09:02 PM Go to last post
  2. Sticky Thread Sticky: FAQs & Guides: Pool Equipment & Operations
    ____________________________________ FAQs & Guides: Pool Equipment & Operations ---- June 2018 ---- ____________________________________ ...
    Started by PoolDoc‎, 06-19-2018 05:06 PM
    06-19-2018 05:06 PM Go to last post
  3. Sticky Thread Sticky: Need advice regarding cartridge filter...
    I've spent the last three years (yes, that's THREE) rebuilding my existing pool that was originally built in the mid 50's. Lots of problems, lots...
    Started by otisdog‎, 05-23-2014 03:45 PM
    05-29-2014 10:38 AM Go to last post
  1. DE Filters - How often do they need to be cleaned?
    I need some info on the DE filter. I know for the sand filters, you need to replace the sand inside the filter every so often. How does it work...
    Started by Mariza‎, 07-10-2006 05:23 PM
    07-10-2006 05:36 PM Go to last post
  2. Insta-Fountain!
    We bought the house with a pool that I'm guessing is over 10 years old. So it doesn't have much in the way of 'water features'. But while trying to...
    Started by aquarium‎, 07-10-2006 02:36 PM
    07-10-2006 04:31 PM Go to last post
  3. Question Solar Systems- 2" vs 1 1/2" Header?
    Hi All, While we're undergoing some pretty heavy pool-deck renovations, we'll be upgrading the pipes of our 20,000 gallon inground concrete pool to...
    Started by CallMeIshmael‎, 06-20-2006 01:40 PM
    07-10-2006 01:37 PM Go to last post
  4. new max-e-pro sta-rite pump & operating questions
    well, with an automated pool vac coming that requires a minimum flow rate to operate ok and changing of furnace, new pipes and wiring change to 220...
    Started by tenax‎, 07-09-2006 10:25 PM
    07-10-2006 01:32 PM Go to last post
  5. Considering 2 speed pump? Here's a cost comparison.
    I wanted to figure out how much money I would save monthly if I were to switch to a 2 speed pump. This calc is done under full load so it may be a...
    Started by cruzmisl‎, 07-10-2006 12:06 AM
    07-10-2006 12:56 PM Go to last post
  6. Clear solar cover options? Magni Clear?
    In searching the forum I see several posts that a clear cover is the better option vs blue and black. I am having a hard time coming up with options...
    Started by PoBoy‎, 06-27-2006 07:32 PM
    07-10-2006 11:01 AM Go to last post
  7. Average Maintenance Costs?
    We are looking at purchasing a pool. Can anyone tell us what the average maintenance costs would be per month? We live in MI and would only use the...
    Started by s6skuzy‎, 07-06-2006 08:29 AM
    2 Pages
    1 2
    07-10-2006 09:55 AM Go to last post
  8. If I looked at the sand in the filter, what should I see?
    Bought the house w/pool April this year and have slowly been rebuilding things to make them work better. It's an IG 15,000 gallon plaster with a sand...
    Started by aquarium‎, 07-02-2006 08:07 PM
    2 Pages
    1 2
    07-10-2006 08:39 AM Go to last post
  9. Heater output is really low, burners not lit
    Hi, all. After 7 years of solid operation, we noticed our heater not putting out the heat it used to. The attached spa used to take a few minutes to...
    Started by mslatter‎, 07-10-2006 12:51 AM
    07-10-2006 01:54 AM Go to last post
  10. I'm considering a solar heater in the midwest (Chicago burb area). Will this work?
    Hi guys and gals, I'm so confused on what decision to make regarding a heater for my 24' round above ground. I've read every thread that the...
    Started by gonefishin‎, 07-06-2006 12:06 AM
    07-09-2006 09:22 PM Go to last post
  11. Question What to do for Vacation
    I am about to take my first vacation since we got our pool. We will be away for 9 days. Does anyone have any tips about what I should do to make...
    Started by MaryS‎, 07-09-2006 12:05 AM
    07-09-2006 11:36 AM Go to last post
  12. How much GPM is my pump producing?
    I have a 2 1/2 HP Sta-rite Maxi-Pro pump and can't find information anywhere on it that says what the GPM is -- only the RPM (even on the web -- I...
    Started by mkelley‎, 07-08-2006 04:25 PM
    07-09-2006 11:32 AM Go to last post
  13. Filter spitting out sand?
    Hey guys, just found this site out of necessity. Just installed a new filter yesterday as the old one stopped filtering completely (dirt would just...
    Started by JohnnyK‎, 07-08-2006 06:00 PM
    07-09-2006 10:31 AM Go to last post
  14. Question Are two-speed pumps worth it? HELP
    I can't get a sreaight answer as to whether to get a single speed or a two-speed pump. I am replacing a dead ITT Marlow 1 HP Argonaut pump and I...
    Started by Ken and Laura‎, 07-03-2006 10:01 AM
    2 Pages
    1 2
    07-07-2006 11:51 PM Go to last post
  15. Outdoor shower
    I'm trying to find an outdoor shower head with a pull chain. I've checked online without any luck. Any ideas?
    Started by DONNIE‎, 07-07-2006 12:49 PM
    07-07-2006 06:06 PM Go to last post
  16. Connect regular PVC fittings to eyeball return in pool?
    Is there a conversion fitting that allows connection of regular PVC pipe fittings to the eyeball returns in the side of a plaster pool? I'm doing the...
    Started by aquarium‎, 07-06-2006 02:07 PM
    pix
    07-07-2006 04:10 PM Go to last post
  17. Pool fountains for in-floor cleaning pools?
    I'm interested in adding a floating fountain to our pool -- it might provide some cooling for the very hot water we get, but I also like the look a...
    Started by mkelley‎, 07-07-2006 03:22 PM
    07-07-2006 03:22 PM Go to last post
  18. sta rite system 3 cardtidge as good as de?
    i was at my local abc pool supply and they were trying to sell me a sys3 cartridge instead of a de saying that these particular cartidges rivaled DE...
    Started by coryinsocal‎, 07-04-2006 03:55 PM
    3 Pages
    1 2 3
    07-07-2006 02:43 PM Go to last post
  19. DE escaping from the filter into the pool...
    I have an older model Hayward EC-65 filter. In the last week or so, I've been noticing small amounts of DE in the pool. So some amount is slipping...
    Started by leejp‎, 06-19-2006 10:12 AM
    2 Pages
    1 2
    07-07-2006 01:10 PM Go to last post
  20. Question for PentairTech on IntelliTouch
    I have the Penatir IntelliTouch i7 automated controller with the MobileTouch (remote) controlling two Pentair pumps, two SAM lights, a SAL light, a...
    Started by mshumack‎, 07-06-2006 12:01 PM
    2 Pages
    1 2
    07-07-2006 12:28 PM Go to last post
  21. Wood heater with Copper heat exchanger
    I have been thinking about buying a Extenda-swim wood burning pool heater. I would like it mostly to bring up pool temp at start up, after cloudy...
    Started by goosegunner‎, 06-30-2006 12:43 PM
    07-07-2006 11:55 AM Go to last post
  22. Right light bulb?
    I ordered a replacement bulb from Leslie's for our Hayward Sp-543 underwater light. Leslie's quoted me $17.45 - vs. $30-40 from the locals. The...
    Started by KirstenHW‎, 07-06-2006 12:57 PM
    07-07-2006 10:39 AM Go to last post
  23. Can't get pump to prime
    I did a dumb thing this morning. :o I backwashed my filter, then set to rinse(which I usually do for 10 seconds). I got called away while rinsing...
    Started by Pamsel‎, 07-06-2006 03:34 PM
    07-07-2006 09:47 AM Go to last post
  24. What do you use to clean your cartridge filter?
    I have a Jacuzzi Sherlok200 filter. Pool startup occurred on June 8. Filter ran 24/7 for 10 days per builder's instructions. At startup it ran at...
    Started by Gracy101‎, 07-06-2006 09:55 PM
    07-07-2006 08:49 AM Go to last post
  25. Cool Need Help with a hose
    Every time we go to vacuum to waste, the hose coming out of the skimmer basket nearly collapses down right in front of the pump. It still is sucking...
    Started by IMherDad‎, 07-06-2006 10:00 PM
    07-07-2006 07:36 AM Go to last post
  26. New Sand after Baquacil Conversion
    Hey all Just finished my conversion from Baquajunk to BBB. Thank Heavens I did it. Couldn't be happier with my pool Now we have to change the...
    Started by lizzie64‎, 07-06-2006 06:05 PM
    07-06-2006 08:25 PM Go to last post
  27. Noisy Hayward booster pump for Viper
    I have installed a Hayward Viper pressure side automatic cleaner and have been happy with the results EXCEPT for the noise from the booster pump. It...
    Started by caldon‎, 07-06-2006 08:15 PM
    07-06-2006 08:15 PM Go to last post
  28. DE in Sand Filter,2spd pump
    I have a 500lb sand filter with a 2spd pump. Added some DE to sand filter on high speed. Do you check for 1psi increase on high or low spd. Also,...
    Started by Davenj‎, 07-06-2006 09:06 AM
    07-06-2006 04:02 PM Go to last post
  29. I think we have a leak...maybe at the skimmmer?
    I am probably about to show my extreme lack of knowledge about pool equipment and such but I guess you have to start learning somewhere...fortunately...
    Started by AndieP‎, 07-04-2006 11:52 AM
    2 Pages
    1 2
    07-06-2006 01:26 PM Go to last post
  30. Filter cartridge cleaning???
    I have a 31 x 15 IG pool, using SoftSwim, and it has filter cartridges. Is there any guideline for how often a good filter needs cleaning? I've...
    Started by mariner09‎, 07-05-2006 01:51 PM
    07-06-2006 01:09 PM Go to last post
+ Post New Thread
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
