+ Post New Thread
Page 53 of 121 FirstFirst ... 3 43 51 52 53 54 55 63 103 ... LastLast
Threads 1561 to 1590 of 3628
Forum: Pool Equipment & Operations
Pumps, pipes, filters, lights; covers, valves, heaters, coolers; filling and draining . . .
  1. Sticky Thread Sticky: How Much Does Pump Efficiency Matter?
    ___________________________________ How Much Does Pump Efficiency Matter? ___________________________________ TL;DR: The difference in...
    Started by PoolDoc‎, 06-23-2018 09:02 PM
    06-23-2018 09:02 PM Go to last post
  2. Sticky Thread Sticky: FAQs & Guides: Pool Equipment & Operations
    ____________________________________ FAQs & Guides: Pool Equipment & Operations ---- June 2018 ---- ____________________________________ ...
    Started by PoolDoc‎, 06-19-2018 05:06 PM
    06-19-2018 05:06 PM Go to last post
  3. Sticky Thread Sticky: Need advice regarding cartridge filter...
    I've spent the last three years (yes, that's THREE) rebuilding my existing pool that was originally built in the mid 50's. Lots of problems, lots...
    Started by otisdog‎, 05-23-2014 03:45 PM
    05-29-2014 10:38 AM Go to last post
  1. Replacing an O-ring
    Hey, I have a leaky o-ring on the top dome of my Hayward S200 sand filter that I am ready to replace. Anything special I need to do to remove...
    Started by anixon7‎, 07-01-2011 09:05 AM
    07-01-2011 05:40 PM Go to last post
  2. In ground pool has pool drain cover plate trying to poke through the liner
    I had my liner replaced two years ago, the installer suggested removing the bottom drain for child safety. As I have a young child I took the advice...
    Started by ocgamer‎, 07-01-2011 10:52 AM
    07-01-2011 05:38 PM Go to last post
  3. I screwed up, EC-65 filter is cracked
    I have been a pool owner and operator for many years, but somehow last year I forgot to drain my Hayward EC-65. When I went to turn it on this year...
    Started by bobjersey‎, 06-03-2010 02:18 PM
    07-01-2011 04:23 PM Go to last post
  4. Source for Jandy DEL60 tank???
    We have a DEL 60 that just developed a leak in the lower tank. I know this has been discontinued in favor of the DEV, but the DEV requires a...
    Started by Geeper‎, 07-01-2011 02:24 PM
    07-01-2011 02:24 PM Go to last post
  5. Cart filter pressure going lower??????
    Hi all. Finally got rid of my mess from the spring. I guess it pays to cover your pool properly. If not you have a nightmare. It becomes a bad...
    Started by Lawrosa‎, 07-01-2011 11:50 AM
    07-01-2011 01:44 PM Go to last post
  6. Hayward Star Clear Plus filter
    Anyone have any opinions on the Hayward Star Clear Filter(C900) I am in the market for an upgrade and would like opinions on the Hayward C900 or...
    Started by brian2170j‎, 07-01-2011 12:26 AM
    07-01-2011 12:26 AM Go to last post
  7. Pool lights
    Currently have two nicheless Aqualumin lights in my pool, I am looking to upgrade to color lights, does anyone have any ideas on this can be achieved...
    Started by JJNMRSDAD‎, 06-30-2011 10:50 PM
    06-30-2011 11:27 PM Go to last post
  8. Wiring Diagram for Polaris 9300
    Got a question, I have a Polaris 9300 robotic cleaner and I was thinking about running the unit off of my solar panels. The manual calls for about 30...
    Started by stuckpipe‎, 06-30-2011 10:18 PM
    06-30-2011 10:18 PM Go to last post
  9. Skimmer Tooth
    Does anyone have a creative idea on how I can repair a Skimmer tooth on one of our Skimmers? To clarify it is what holds the flap in the Skimmer. The...
    Started by BBB's‎, 06-29-2011 02:45 PM
    06-30-2011 01:41 PM Go to last post
  10. Unhappy Pressure rising quickly
    Great forum learned alot from reading but I am now stumped, Please HELP. I have a tagelus TA-50 sand filter with a 1.5 hp pump on a 20ft ag. I...
    Started by dsimpson‎, 06-28-2011 08:26 PM
    06-29-2011 10:01 PM Go to last post
  11. How full should my sand filter be with sand?
    My pool just doesn't seem to be clearing up and I was wandering if it was a filter problem. I took the top off of my sand filter and it is half full...
    Started by tyandnikki‎, 06-29-2011 08:16 PM
    06-29-2011 09:21 PM Go to last post
  12. Question Flowmeter Placement Questions
    Three quick questions: Can I install a pitot tube type flowmeter in the straight section of pipe leading to the pump inlet? Will it work on the...
    Started by BigDave‎, 06-24-2011 12:37 PM
    2 Pages
    1 2
    06-29-2011 07:48 PM Go to last post
  13. New DE filter installed worked fine till first backwash now it has 0 psi pumppressure
    Hey im looking for some guidence on a new self installed Hayward DE4820 48sqft, 96GPM, 363LPM which takes 6 lbs of DE per backwash. I have it mated...
    Started by ocgamer‎, 06-27-2011 09:12 AM
    06-29-2011 07:21 PM Go to last post
  14. Help on types of sand filter media
    I have several questions: Are Zeosand and Zeobrite the same thing? Are there different brands of sand media? Is Zeosand a knock off? What is the...
    Started by sharks9022‎, 06-29-2011 04:24 PM
    06-29-2011 05:38 PM Go to last post
  15. aqualogic table top remote question
    So I've got a 5 year old Aqua Logic system managing my pool operation, and a remote (wireless) for it that we keep inside (GLX-TB-RF-PS-8). I'm...
    Started by buck1s‎, 06-29-2011 08:13 AM
    06-29-2011 11:09 AM Go to last post
  16. help with and old sand filter
    I have a older hayward gm 140 4 port sand filter and I need to know how to connect it to my pump and pool there isn't and arrows or markings on the...
    Started by chris‎, 06-28-2011 01:04 AM
    06-28-2011 10:13 PM Go to last post
  17. Jacuzzi Skimmer Operations
    I can't for the life of me figure out how to get my skimmer to have a 50/50 mix between MD and skimmer. I tried yesterday by moving the trimmer plate...
    Started by byron366‎, 06-28-2011 01:17 PM
    06-28-2011 10:11 PM Go to last post
  18. HELP! First filter breakdown and it's full of pieces of what looks like "cement"???
    Our pool initially opened less than a year ago and the pressure was up, so we decided to go ahead and have the annual filter breakdown cleaning...
    Started by lkafrazier‎, 06-27-2011 03:02 PM
    06-28-2011 08:42 PM Go to last post
  19. Question Hayward Ec40ac blowing dirty into pool
    We just bought a house in the fall that came with a pool. Everything was winterized, pump and filter drained and brought inside. Everything this...
    Started by davesdog‎, 06-28-2011 01:58 PM
    06-28-2011 02:52 PM Go to last post
  20. Heater Pilot Won't Stay Lit
    I have a Hayward CZ150-1 millivolt pool heater for my 16x32 above ground pool. It's old. Every year it's a chore to light the pilot. I usually...
    Started by hayshaker170‎, 06-28-2011 10:17 AM
    06-28-2011 01:29 PM Go to last post
  21. pool sweep
    I've read alot on the forum about algae and how to get rid of it.I think I'm ready to get started. My question is when I'm running the filter 24/7,...
    Started by jlynnek‎, 06-28-2011 11:31 AM
    06-28-2011 12:59 PM Go to last post
  22. No power to pump? Fuse blown. Replaced & didnt fix
    I have a jandy lite 2 wired 110 controlling a pump wired 220. My electrician friend who does many pools set this all up and has been trouble free 7...
    Started by topnotch‎, 06-26-2011 07:00 PM
    fuse blown, jandy, lite 2, pump
    06-27-2011 11:40 PM Go to last post
  23. Replacemet Cartridges
    Is there a difference in replacement cartridges for in ground pools? It seems like prices are anywhere from $30-$100 for the size I need. Multiply...
    Started by joewilly1‎, 06-27-2011 04:19 PM
    06-27-2011 04:19 PM Go to last post
  24. Sand in pool?
    OK, I'm back again with more questions. ;) I thought our pool filter was putting dirt back into our pool, but I think it may be sand. How do you...
    Started by JenLM‎, 06-25-2011 10:09 PM
    06-27-2011 04:03 PM Go to last post
  25. SAVI Melody LED light
    We just had a new pool built and the light is now defective one week after filling. Has anyone else has any problems with the Savi LED lights?
    Started by emowrer‎, 06-27-2011 09:51 AM
    06-27-2011 10:37 AM Go to last post
  26. Question Considering investing in a cover for this fall
    I have said it for the past 3 years and never go through with it, then regret the full day's labor to get all the leaves out in the spring. I am...
    Started by jilted‎, 06-27-2011 02:13 AM
    06-27-2011 02:13 AM Go to last post
  27. Question on Raypak 2100 Pool Heater
    I have a Raypak 2100 pool heater, model PR 335A-EN. It is 12 years old and has begun giving me problems. The digital control panel went out years ago...
    Started by Canaligator‎, 06-25-2011 05:59 PM
    06-26-2011 09:35 PM Go to last post
  28. What pump for Hayward DE 6000 Filter?
    I have a 50 year old 44,000 gallon (20x40) gunite pool freshly painted. I currently have a 2.5 horse Hayward Super II. Starting to question the...
    Started by johnrieb‎, 06-25-2011 12:22 PM
    06-26-2011 08:27 PM Go to last post
  29. Ladder 'feet' are mildewy
    The little rubber/vinyl 'feet' that fit on the wall end of my stainless steel ladder that keep the ladder from cutting holes in the inground vinyl...
    Started by KirstenHW‎, 06-26-2011 09:43 AM
    06-26-2011 08:13 PM Go to last post
  30. Connecting Pentair MobileTouch2 to i5 system
    We moved into a house with a pool. The existing MobileTouch remote was broken, so the home warrant company sent us a new one. The only problem is the...
    Started by KnightsArmy‎, 05-16-2011 09:52 PM
    06-26-2011 08:07 PM Go to last post
+ Post New Thread
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
