+ Post New Thread
Page 5 of 121 FirstFirst ... 3 4 5 6 7 15 55 105 ... LastLast
Threads 121 to 150 of 3628
Forum: Pool Equipment & Operations
Pumps, pipes, filters, lights; covers, valves, heaters, coolers; filling and draining . . .
  1. Sticky Thread Sticky: How Much Does Pump Efficiency Matter?
    ___________________________________ How Much Does Pump Efficiency Matter? ___________________________________ TL;DR: The difference in...
    Started by PoolDoc‎, 06-23-2018 09:02 PM
    06-23-2018 09:02 PM Go to last post
  2. Sticky Thread Sticky: FAQs & Guides: Pool Equipment & Operations
    ____________________________________ FAQs & Guides: Pool Equipment & Operations ---- June 2018 ---- ____________________________________ ...
    Started by PoolDoc‎, 06-19-2018 05:06 PM
    06-19-2018 05:06 PM Go to last post
  3. Sticky Thread Sticky: Need advice regarding cartridge filter...
    I've spent the last three years (yes, that's THREE) rebuilding my existing pool that was originally built in the mid 50's. Lots of problems, lots...
    Started by otisdog‎, 05-23-2014 03:45 PM
    05-29-2014 10:38 AM Go to last post
  1. Air in the system
    Hello all and welcome to another season. My pump runs for about 6 hours in the morning and then shuts off. When it first kicks on in the morning...
    Started by Phillbo‎, 04-16-2017 02:08 PM
    04-25-2017 03:25 PM Go to last post
  2. Help...Sand Filter leaking
    A little concerned about our large sand filter. A very small amount of water seems to be seeping through the fiberglass at the top of the filter. I...
    Started by Fiveattripp‎, 04-17-2017 08:59 AM
    04-19-2017 11:45 AM Go to last post
  3. Pentair check valve/divertor
    Does anyone have a suggestion for a temporary solution to stop a damaged check valve/ divertor from leaking? Lost about a foot of water last night...
    Started by donfranko‎, 03-18-2017 11:01 AM
    04-16-2017 06:21 PM Go to last post
  4. Pool newbie
    Hi Everyone :-D Myself and the wife recently bought our new ( to us ) home and it came with a pool. We have thus far understood the basics of...
    Started by Limeybiscuit‎, 07-14-2011 09:20 PM
    03-26-2017 11:20 PM Go to last post
  5. Ozone or chlorine-above ground pool in FL
    I am SO confused! Which one is the best AND easiest? Need to make up my mind so I can buy the pool. I have everything else picked out. THANKS...
    Started by kimkats000‎, 06-30-2012 09:08 PM
    03-25-2017 11:17 PM Go to last post
  6. Pop up replacement: QucikClean#3(and tool) source?
    Helping a friend fix a few things with their Shasta pool(phoenix), several of the pop ups are broken and we have been told they are QuickClean #3 ....
    Started by BND‎, 03-21-2017 12:07 PM
    03-23-2017 03:03 PM Go to last post
  7. What kind of eyeball return jet is this?
    I need to replace some broken eyeball return jets in my pool, but I'm confused about one of them as it's not a regular threaded eyeball, but it's...
    Started by CandyMoss‎, 03-11-2017 07:04 PM
    03-16-2017 12:15 AM Go to last post
  8. Need new pump. Buy seals too? Quick response needed!
    My 10 year old Hayward Superpump is sounding like its on its last leg so I plan on replacing it ASAP before it dies. Last year I replaced the seals...
    Started by JimK‎, 06-19-2013 08:20 PM
    03-10-2017 09:33 PM Go to last post
  9. Help - pump running, flow runs dry
    If I fill pump well full of water, for several minutes, it bubbles and fills up, close lid cut on pump, it starts prime sequence, sucks all water out...
    Started by Wraypau‎, 02-05-2017 09:14 PM
    02-07-2017 02:19 PM Go to last post
  10. Question Pump not pulling in water to strainer basket (clogged pipe?). Pump is okay.
    I am having an unusual problem. My pump is not filling with water (the strainer basket is empty). This is a 1 HP Whisperflow on 20K in-ground pool....
    Started by CountryBumkin‎, 01-09-2017 08:34 AM
    clogged line, pump failure, pump suction
    01-15-2017 01:58 AM Go to last post
  11. Motor Square Flange Stuck to Pump Housing Seal Plate
    I'm trying to replace the bearings in my Century B2982 motor, but I cannot separate the motor flange from the pump housing's seal plate. The pump is...
    Started by vgg659‎, 10-08-2016 12:50 PM
    10-29-2016 03:32 PM Go to last post
  12. Lite2 pump button won't start pump
    First, I love this forum and am so glad it's still around. It is my first source for help/information about my pool. I can't find a question/answer...
    Started by grpools‎, 10-28-2016 03:24 PM
    10-28-2016 03:24 PM Go to last post
  13. Pump Motor Capacitor
    Our in-ground pool pump (Hayward Super 2) would not start this morning - the switch turned on, it hummed for several seconds, and then shut off. I...
    Started by matthewnadeau‎, 10-22-2016 06:05 PM
    10-22-2016 06:05 PM Go to last post
  14. Question Polaris Wall Hook-Up is Draining Pool
    We have never had this problem. We recently got a new Hayward pump. We replaced the wall hook-up as the other one broke. We are now having our...
    Started by crandies‎, 10-18-2016 08:47 PM
    10-18-2016 08:47 PM Go to last post
  15. Liner leaking what to do?
    Have a water loss of 1" 24 hours due to liner leak. Plumbing tested and other opening areas tested with dye. Had a diver replace the hydrostatic...
    Started by essikr‎, 09-24-2016 09:40 AM
    09-25-2016 10:39 AM Go to last post
  16. pool leak?
    I have an inground pool 18 x 32 with steps. I done the Pool bucket test. It stays the same when the pool is off. When I turn it on I lose about 1/2...
    Started by phillipjko‎, 09-07-2016 07:03 AM
    09-08-2016 11:16 AM Go to last post
  17. Hayward Power Flo Matrix power switch wiring
    Been a while since I have needed help with my pool, things were going good for the past couple of years until now... Having issues with my pump and...
    Started by sunlove‎, 09-03-2016 11:44 AM
    09-03-2016 11:44 AM Go to last post
  18. Question DE Filter - Grid has Ripped
    We have a Jandy DEL60 Filter. Several of our grids have tears in them. We have replaced all the large grids, but have to wait another week for the...
    Started by applepar‎, 08-27-2016 03:04 PM
    de filter, grids, ripped grid
    08-29-2016 05:19 PM Go to last post
  19. Air coming in?
    Long time since I've been here but that's (mostly) because I've had no issues for years. Now all of a sudden I'm getting a tremendous amount of...
    Started by mkelley‎, 08-20-2016 05:32 PM
    08-24-2016 10:34 PM Go to last post
  20. Do I need to replace both pumps?
    Had a energy audit by the electric company. They advised to change to a variable speed pump to save energy. I have two 1 hp pumps one is labeled...
    Started by itybitybob‎, 08-12-2016 04:39 PM
    08-23-2016 07:15 PM Go to last post
  21. DE Fillter....
    I back washed my pool and forgot to add DE before the timer turned it on. It ran for about 4 hours before I realized my mistake and added the normal...
    Started by Phillbo‎, 08-11-2016 03:08 PM
    08-18-2016 01:57 PM Go to last post
  22. Shaft Seal Leak Comes and Goes
    2 years ago I had a drip leak from the bottom of the pump housing. I replaced the shaft seal and it stopped. However, since then, the drip has...
    Started by Steveromo‎, 07-02-2016 02:55 PM
    08-12-2016 09:10 PM Go to last post
  23. Shutting Pump Off & Covering For Vacation. Tips?
    Hi Gang. Saw dozens of vacation posts (including mine from '14.) But this time I am in a different situation. I MUST shut down my pump for the 8 days...
    Started by Steveromo‎, 07-11-2016 07:56 PM
    08-04-2016 09:34 PM Go to last post
  24. Trouble Shooting Question w video: Will leak cause cavitation?
    Howdy! I have a Challenger 1&1/2HP, pieced a repaired over the last 25+ years. The pump has run dry a couple of times this winter and spring. The...
    Started by AlgaeFarmer‎, 06-21-2016 01:53 PM
    07-27-2016 06:27 PM Go to last post
  25. Automatic Pool Cover closing issue
    We have an Automatic Pool Cover installed on our pool. When I turned the key switch tonight to close the cover, a solid red light came on the key...
    Started by krdowns‎, 07-19-2016 09:18 PM
    07-24-2016 11:50 PM Go to last post
  26. Sand Master Soft Sided Above Ground Pool Sand Filter for 15'x48" Intex Metal Sided
    Will the Sand Master soft sided above ground pool filter listed here...
    Started by ransomedbyfire‎, 07-16-2016 03:36 AM
    07-16-2016 03:36 AM Go to last post
  27. Pump getting hot
    The outside casing of my Hayward pool pump (in ground pool, 1.0 hp pump) seems to get very hot, almost where you cant touch it. Is that normal or am...
    Started by sabres07‎, 06-19-2016 12:08 PM
    06-19-2016 12:08 PM Go to last post
  28. Hayward EC-65 Perflex repair/replace.
    I was having some pressure issues with my Ec-65 pump would run for about half an hour and then the pressure would rise to 25 and very little water...
    Started by sparklewater‎, 06-09-2016 07:39 PM
    06-09-2016 07:39 PM Go to last post
  29. Question Pool Pump Fried?????
    Hey all. Have a Hayward Pump wired to 220V. Been running great for 10 years. Yesterday, all of a sudden it started to shut off after about 2...
    Started by Nevets‎, 06-08-2016 11:47 AM
    06-08-2016 07:36 PM Go to last post
  30. H ayward Ecostar 3400 Error : Communication failed check wiring between display and d
    My pool pump stopped working today. It is a Hayward 3400 SVP. The error code i am getting is. Check System communication failed check wiring...
    Started by Wraypau‎, 06-06-2016 09:09 PM
    06-06-2016 09:09 PM Go to last post
+ Post New Thread
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
