+ Post New Thread
Page 12 of 121 FirstFirst ... 2 10 11 12 13 14 22 62 112 ... LastLast
Threads 331 to 360 of 3628
Forum: Pool Equipment & Operations
Pumps, pipes, filters, lights; covers, valves, heaters, coolers; filling and draining . . .
  1. Sticky Thread Sticky: How Much Does Pump Efficiency Matter?
    ___________________________________ How Much Does Pump Efficiency Matter? ___________________________________ TL;DR: The difference in...
    Started by PoolDoc‎, 06-23-2018 09:02 PM
    06-23-2018 09:02 PM Go to last post
  2. Sticky Thread Sticky: FAQs & Guides: Pool Equipment & Operations
    ____________________________________ FAQs & Guides: Pool Equipment & Operations ---- June 2018 ---- ____________________________________ ...
    Started by PoolDoc‎, 06-19-2018 05:06 PM
    06-19-2018 05:06 PM Go to last post
  3. Sticky Thread Sticky: Need advice regarding cartridge filter...
    I've spent the last three years (yes, that's THREE) rebuilding my existing pool that was originally built in the mid 50's. Lots of problems, lots...
    Started by otisdog‎, 05-23-2014 03:45 PM
    05-29-2014 10:38 AM Go to last post
  1. Question 18x36 oval inground, need to heat and cover and clean
    OK. Had a pool growing up, tech seems to have changed a lot! Am in Massachusetts -- Boxborough to be specific. Pool is an inground 18x36...
    Started by acpatel‎, 06-22-2014 01:03 PM
    06-23-2014 05:43 PM Go to last post
  2. Lightbulb Pump having problem starting up
    So this morning I noticed that my pump took over 10 tries to get going. When I went out I noticed that the filter pressure gauge was at 0 and the...
    Started by mfhache‎, 06-06-2014 08:14 AM
    06-23-2014 01:06 PM Go to last post
  3. Solar blankets, floating rings, or other heaters
    Hi everyone! Has anyone tried solar blankets or floating rings? We live in upstate NY and would like to take a bit of the chill off the pool so...
    Started by dagny0823‎, 06-22-2014 12:00 PM
    06-22-2014 01:27 PM Go to last post
  4. Question Hayward superpump sucking air
    HI All, I just had all of the plumbing redone on our in ground pool and I have a Hayward Superpump. The skimmer pot is clear of any air bubbles but...
    Started by lexicon123‎, 06-19-2014 07:32 AM
    06-22-2014 07:49 AM Go to last post
  5. Question Pool vacumn and skimmer confusion
    I have a 32,000 gal plaster pool. I have never really known how to use the vacumn. I know about the valve settings and the vacumn. What I don't...
    Started by crandies‎, 06-21-2014 05:27 PM
    06-21-2014 05:27 PM Go to last post
  6. Filter and Pump working together?
    I recently purchased a new home with an in ground pool. We opened the pool last year and couldn’t get it clear for the life of us. We balanced our...
    Started by BrandonJamesD‎, 06-19-2014 11:42 AM
    06-21-2014 04:25 PM Go to last post
  7. Small Niche and LED light
    I have a fiberglass in ground pool. Because of the curve my installer installed a spa niche at the end of the 40 foot length. He said the normal size...
    Started by Canar‎, 06-17-2014 07:43 PM
    06-21-2014 10:26 AM Go to last post
  8. Hayward EC-30 DE Filter suction problem
    Hi. I have the above filter on a 24' above ground pool with a 1hp power flo matrix pump. Out of the blue..i cannot get a good size air bubble out...
    Started by mjd331‎, 06-18-2014 12:18 PM
    06-20-2014 08:29 AM Go to last post
  9. Finding & Fixing Suction-side Pool Leaks
    _____________________________________________ Finding & Fixing Suction-side Pool Leaks _____________________________________________ ...
    Started by PoolDoc‎, 06-20-2014 08:16 AM
    06-20-2014 08:16 AM Go to last post
  10. Check valve question
    My spa/pool is set up so that the main pump sends the water to the spa first and then the water exits the spa and goes into the pool, then back to...
    Started by Rockman59‎, 06-18-2014 11:29 PM
    06-19-2014 01:56 PM Go to last post
  11. converting to LED
    Have and old light that has been leaking and throwing the GFI. Ive decided to change over to LED and have found a good sealed unit, but i need a...
    Started by BND‎, 06-06-2014 08:10 PM
    06-19-2014 09:45 AM Go to last post
  12. variable speed with heat pump and salt water generator
    If I'm running a variable speed pump on low rpms can this cause any issues with a salt chlorine generation system or the heat pump?
    Started by neverstopplaying‎, 06-18-2014 01:28 PM
    06-19-2014 09:36 AM Go to last post
  13. newbie here.....filter is toast.....which filter should we get?
    Long story short.....we bought a house 8 months ago with a large inground "L" shaped pool. 18x42 with 18x20 L, so approx. 47,000 gals (it's...
    Started by cathicool‎, 06-15-2014 10:06 PM
    2 Pages
    1 2
    sticky, sticky-contractor, sticky-filter
    06-18-2014 10:45 PM Go to last post
  14. Cool another pool season starts
    hello fellow pool enthusiasts! I read through a some posts a few years to bring up my knowledge of pool chemistry. This is one of the few places...
    Started by neverstopplaying‎, 06-17-2014 09:46 PM
    06-18-2014 12:57 PM Go to last post
  15. Hayward pump cutting out several times a day - is this normal?
    I have a 30,000-gallon in-ground w/ a Hayward pump (SP2607X10). It's driven by a 1HP A.O Smith motor that runs on 220V. The pump is on a timer that...
    Started by Tommy‎, 07-07-2013 03:28 PM
    2 Pages
    1 2
    06-18-2014 09:45 AM Go to last post
  16. Backwash
    Hi all, Newbie here and trying to figure out how to backwash a DE filter that has no handle. We bought a home that came with a: Proline...
    Started by rkovelman‎, 06-17-2014 09:49 PM
    06-18-2014 08:06 AM Go to last post
  17. new variable speed pump and solar heating system
    Hello there, I had a new Hayward 3400VSP pump installed yesterday to replace a 5 year old 1.5hp hayward and it keeps getting stuck priming during...
    Started by michelleh220‎, 06-15-2014 03:01 PM
    06-17-2014 03:42 PM Go to last post
  18. Solar cover straps?
    Any good leads on straps to connect my solar cover to the reel? I need a longer length, maybe 30-36". The reel is anchored hard into the concrete,...
    Started by glockshooter‎, 06-16-2014 10:42 PM
    06-16-2014 10:42 PM Go to last post
  19. Size of skimmer vac hose opening - inground pool
    We have a new skimmer installed when our pool was renovated last year. I have a robot cleaner, so haven't had to use our vac hose till now. And I...
    Started by handy1‎, 06-15-2014 03:01 PM
    06-15-2014 03:01 PM Go to last post
  20. pool filter time trippers turn-on, turn-off not working
    Hi, Our pool filter has a round dial with two trippers, one to turn on the filter, one to turn off the filter. In the past we could place the...
    Started by vinouspleasure‎, 06-15-2014 12:18 PM
    06-15-2014 01:29 PM Go to last post
  21. Jandy Check Valve rusted spring
    Does anyone know of a replacement spring that can be purchased for Jandy Check Valve. "thanks for your input"
    Started by michaelfl‎, 06-13-2014 02:36 PM
    06-14-2014 10:21 PM Go to last post
  22. Pool Heater size
    Hello all: I had a 400,000 BTU Raypack 2100 heater which died last month after 12 years. I had a new heater installed and asked for another...
    Started by RSM18‎, 06-12-2014 08:35 AM
    06-14-2014 03:25 PM Go to last post
  23. Getting debris in return from Pentair DE filter, but no DE
    Hi, I recently had trouble with DE getting sent back into the pool from my Pentari 60" DE filter. You could see it coming thru the return. I...
    Started by pktivey‎, 06-11-2014 06:03 PM
    06-14-2014 03:05 PM Go to last post
  24. Hayward H1501
    About 7 years old. I think I need a new gas valve. The heater does not start up. I jump across the terminals on top of the gas valve and usually...
    Started by curtis1512‎, 06-11-2014 02:51 PM
    06-14-2014 01:39 PM Go to last post
  25. Is this causing sand to go into the pool?
    I pulled the top off my old Media Master 19" this morning because in the past 2 days it's belched an unusually large amount of sand into the pool. ...
    Started by Bosch232‎, 06-14-2014 09:32 AM
    06-14-2014 09:32 AM Go to last post
  26. pentair dynamo pump issues
    hello new to the forum and looking for advice on my dynamo pump. My pump wouldn't start Monday evening after back washing, it just hummed. The motor...
    Started by bjreed1999‎, 06-11-2014 09:36 AM
    06-13-2014 10:00 PM Go to last post
  27. Hayward H250 heater blowing fuses
    My Hayward heater ran for about 2 hours this spring and then blew the #2 position fuse on the AC supply side. I found a troubleshooting manual online...
    Started by windypool‎, 06-12-2014 10:52 PM
    06-12-2014 10:52 PM Go to last post
  28. Pentair Clean and Clear
    We opened our Pentair Clean and Clear to change the filters and now that we have it closed back again, it is leaking around the seal. We have...
    Started by AllBoys‎, 06-10-2014 08:52 PM
    06-12-2014 01:27 PM Go to last post
  29. Electricity and GFI tripping
    I have 24'round AG, about 12,000 gallons. The pump is only 2 or 3 years old and is probably 1 hp. I have an electrical circuit running the...
    Started by dalejanus‎, 06-11-2014 10:10 PM
    06-12-2014 11:00 AM Go to last post
  30. De Filter EC40
    I would like to replace some of my Flex Tubes socks, but I can only find the tube with the socks. I've search and search the internet but no luck....
    Started by ltpowel‎, 06-11-2014 07:53 AM
    06-11-2014 07:53 AM Go to last post
+ Post New Thread
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
